marcus
Dearly Missed
- 24,753
- 795
RandallB said:Marcus
On Strings I feel it’s future may well becoming a waste land. But I believe it has been very valuable in identifying the 11 dimensions issue. Lack of progress indicates that this idea is likely just wrong. But ANY future theory that proves 11 D as wrong, should also be able to explain why the 11 D issue appeared to be viable at all. Just this additional ‘test’ of future theories, I think that can be worth quite a bit.
Also, You mentioned something else I could use a little help on “how I think”
Among tested, well-established theories, General Relativity is the most background independent model we have.
Having never really put it into words before, but I’d though of GM as background dependent. That is with the “warping” of space time was still a manipulation of a background dependent interpretation of space and time.
Your comment tells me I need to Fine Tune my thinking a bit...
this is a sign we need a link to basic Differential Geometry primer where the idea of a "differentiable manifold" (often a "smooth manifold") is defined
does anyone have an Intro to D.G. or Intro to Manifolds link?
Randall there are two abstr. math. ideas you need that are actually very simple and easy to get-----Manifold and Metric-on-the-manifold.
For 150 years the fundamental paradigm for a continuum that everyone uses is a Manifold (defined by Riemann around 1850).
the most common meaning of B.I. is you start with a Manifold without a metric.
in a B.D. theory you start with a manifold and give yourself a metric on it to start with as well
have to go back later
