Is Studying Planar Multibody Dynamics Essential for Mechanical Engineers?
Studying planar multibody dynamics is valuable for mechanical engineers, despite the availability of advanced software like MATLAB's SimMechanics and other CAD tools that simplify analysis. While many engineers rely on practical experience and basic calculations for common mechanisms, understanding the underlying theory enhances the ability to interpret results and troubleshoot issues effectively. Advanced software such as Simpack and MSC Adams is used for complex motion analysis, but foundational knowledge remains crucial for accurate modeling and analysis. Theoretical understanding aids in setting up analyses and verifying results, similar to the principles in Finite Element Analysis. Ultimately, a balance of theory and practical application is essential for successful engineering design and implementation.
zoltrix
Hello
I am reading the book :
" Planar Multybody dynamics, Formulation, Programming and Application"
An interesting lecture , however is it worthwhile studying these methods for kinematic and dynamic analysis of mechanical mechanisms?
I mean
There are many softwares on the market which make the job for you, for example "multibody" by MatLab ( ex Simmechanics)
what did mechanical engineers actually use on job ?
maybe none of them just the experience ?
Few practicing mechanical engineers ever perform analytical analyses of multibody dynamic mechanisms. Most dynamic mechanisms simplify down to a servomotor or crankshaft moving a load. Most of those cases are solved by first calculating the position, velocity, and acceleration vs time. Components are sized to meet requirements of stiffness, inertia, and strength. Peak drive torque is calculated, and the drive is sized. More advanced problems require an understanding of torsional natural frequency, and calculating an appropriate motion profile. Dynamic mechanism typically also require calculating the total system inertia reflected to the drive motor.
I had one job where the best solution used a four bar linkage driven by a servomotor. I wrote a Matlab program to plot the output motion, and used that program to iteratively design the linkage. The peak acceleration was twice the peak acceleration of a similarly sized crankshaft, which was all the necessary information to size the parts. After sizing the servomotor, it was built, started up, and it worked. Durability testing resulted in several redesigns to improve bearings and mounting of change parts.
Simulating motion is the easy part. The challenge is in designing and building something that actually works in the hands of a customer, and keeps working.
Likes hutchphd, anorlunda, berkeman and 1 other person
In practice, advanced MBD software such as Simpack and MSC Adams is used to analyze the motion of complex mechanisms and machines. Basic motion studies can also be performed in proper modules of CAD software like Autodesk Inventor, Fusion 360 or SolidWorks. They all offer quite advanced motion studies with evaluation of displacements, velocities, accelerations and forces, among the others. If you don't have a license for such software but would like to try something like that, check the open-source solutions. For example, you can find the add-on "Dynamics" module for FreeCAD which uses MBDyn as a solver. Its capabilities are quite impressive:
Here's a GitLab repository of this module: https://gitlab.com/josegegas/freecad-mbdyn-dynamics-workbench
However, I still think that theory can be useful. It's like with Finite Element Analysis where a software can do almost everything for you but you won't be a good analyst without the knowledge about the theory behind this method and behind solid mechanics or whatever physics are involved in your analysis. For example, you can't interpret the results properly if you don't fully understand the meaning of each output variable and don't know how your model should behave under specific loading. Setting up the analysis also requires understanding of various aspects such as material models and boundary conditions. And when something fails, you have to dive deep into the problem from the perspective of a solver. You have to understand the Newton-Raphson method to know why the analysis is divided into increments and iterations and so on. Not to even mention the verification with analytical solutions which is very often necessary in the case of FEA. Multibody dynamics simulations are different but many of these remarks still apply in some ways.
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
