Is the air in a room an ideal gas?
Air at room temperature behaves like an ideal gas because the temperature is significantly higher than its boiling point, minimizing the effects of intermolecular forces. At this temperature, pressure, and volume, the distance between gas molecules reduces the influence of attractions and repulsions. While density is related to volume, it does not directly determine whether air is an ideal gas; rather, the spacing of molecules is more critical. The relationship between density and volume is given by the equation rho = m/V, where density is proportional to volume. Overall, the characteristics of air at room temperature support its classification as an ideal gas.
bse
Is the air in a room an ideal gas? How do you know this?
How does this compare to the density of air at room temperature?
thanks
this can probably go into the General Physics or Classical Physics forum.
air at room temp is pretty close to an ideal gas because its temp is much higher than its boiling point.
Ok sorry,
thanks a lot
it is an ideal gas because the weird forces of attraction and repulsion (Such as hydrogen bonding, diploe-dipole stuff) have very little effect at this temperature, pressure and volume. This is true because the molecules in this gas have enough distance in b/w them at this P,V,T.
Density doesn't really directly have anything to do with this. rho = m/V = (n*MM)/V, the only variable here is V, so density is proportional to the volume, but it as i mentioned above it is the distance b/w the molules that matters, and this of course is related to the density, so that's how the density factors in.
Hope that helps
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 109 ·
  • · Replies 24 ·
