Is the Angle Between Acceleration and Velocity Vector Greater Than 90 Degrees?
An object moving clockwise on an oval track experiences a change in velocity due to decreasing speed. At point G, the velocity vector is tangent to the curve, while the acceleration vector has two components: centripetal acceleration pointing inward and tangential acceleration opposing the direction of motion. The angle between the acceleration vector and the velocity vector at point G is greater than 90 degrees because the acceleration vector is not aligned with the velocity vector. The reasoning clarifies that the acceleration vector results from both a change in speed and direction. Understanding the relationship between these vectors is crucial for solving the problem accurately.
KatlynEdwards
An object moves clockwise with decreasing speed around an oval track. There are velocity vectors at two points (G and H). G has a greater speed than H. Is the angle between the acceleration and velocity vector of G greater than, less than, or equal to 90 degrees?
N/A
So I know when it's in constant motion the acceleration vector is perpendicular to the velocity and point's towards the inside of the oval. But since in this instance it's slowing down, that means that the delta v vector is angled because one of the legs of the triangle is shorter. So my thoughts are that it is larger than 90 degrees. Is this the right line of thinking?
Thanks for your input!
Your answer may be correct but your reasoning is not. The problem is asking for the angle between the velocity vector (not the change in velocity vector) and acceleration vector at a point G. The velocity vector is tangent to the curve at that point, and points in the direction of the tangential motion. One component of the acceleration vector points inward toward the center of the curvature (centripetal acceleration), and the other acceleration component (at a right angle to the centripetal acceleration vector) is tangent to the curve, pointing opposite to the direction of the velocity vector because it is slowing down. Draw a quick sketch showing the velocity vector and the resultant of the centripetal and tangential acceleartion vectors (the total or net acceleration) and determine if the angle betwen the two is >, <, or = to 90 degrees.
Oh, I was under the impression that the acceleration vector was parallel to the change in velocity vector, is this false?
Well that is true...but the velocity vector is changing due to both its change in direction and its change in magnitude...its change in direction gives it a centripetal acceleration, v^2/r, pointing inward to the center of curvature, and it's change in speed gives it a tangential deceleration...the vector addition of those 2 acceleration vectors is the direction of the acceleration...so at point G, the velocity vector is tangent to the curve, but the acceleration vector is not...the angle between the 2 is greater than, less than, or equal to 90 degrees? (Your answer is correct...I am not sure from your wording though if you understood why...).
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
