MHB Is the Complexity of Satisfiable Boolean Expressions in NP?
The discussion centers on the representation of Boolean expressions and the classification of the language L, which consists of all strings representing satisfiable Boolean expressions. The claim is made that L is in NP, supported by a nondeterministic algorithm that guesses a satisfying assignment of binary values to the variables. The process involves substituting these values into the expression, which may require adjustments to the string format, and then evaluating the expression to check if it yields a value of 1. The evaluation can be performed in polynomial time, even with basic algorithms, leading to the conclusion that determining the satisfiability of a Boolean expression is indeed in NP. The explanation emphasizes the steps of guessing, substitution, evaluation, and acceptance based on the result, suggesting that a clear understanding of these steps is crucial for implementing the algorithm in programming languages.
mathmari
MHB
Hey! :o
The Boolean expression $(p_1+p_2)*p_3$ can be represented by the string $(1+2)3$, where integer $i$ represents variable $p_i$.
Consider the language $L$ consisting of all strings representing satisiable Boolean expressions (those for which some assignment of $0$'s and $1$;1 to the variables gives the expression the value 1).
We claim that $L$ is in $\mathcal{NP}$.
A nondeterministic algorithm to accept $L$ begins by "guessing" a satisfying assignment of $0$'s and $1$'s to the propositional variables in an input string, if such an assignment exists.
Then, the value ($0$ or $1$) of each variable is substituted for the variable wherever it occurs in the input string.
Some shifting of the string will be needed to close up gaps when the single symbol $0$ or $1$ is substituted for a decimal representationm of a propositional variable.
Then the resulting expression is evaluated to verify that it has the value $1$.
The evaluation can be done in time proportional to its length by a number of parsing algorithms.
Even without using an efficient parsing algorithm, the reader should have a little trouble evaluating a proposition in $O(n^2)$ steps.
Hence there is a nondeterministic Turing machine of polynomial time complexity to accept satisfiable Boolean expressions, and thus the problem of determining whether a Boolean expression is satisfiable is in $\mathcal{NP}$.Could you explain me how we have shown that there is a nondeterministic Turing machine of polynomial time complexity to accept satisfiable Boolean expressions?? (Wondering)
I haven't understood it...
Technology news on Phys.org
The details are a bit messy, but the idea is the following.
(1) Nondeterministically choose a sequence of $n$ zeros and ones where $n$ is the number of variables in the expression.
(2) Substitute chosen values for variables. The result is an expression containing 0, 1 and operations.
(3) Evaluate the resulting expression.
(4) Accept if the result is 1.
With some handwaving one can show that this requires polynomial time. I recommend understanding this first if you write this algorithm using not a Turing machine, but your favorite programming languages with all data structures (such as trees) and standard functions available.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
