Is the concept of reactive centrifugal force valid?
In summary, the article is incorrect in its assertion that the reactive centrifugal force is always centrifugal. It depends on the context.
  • #211
A.T. said:
Nonsense. Forces from attached ropes are electro-magnetic interaction forces, and act in every frame. Inertial forces in non-inertial frames are not acting trough attached ropes, but directly on every piece of mass.
Two ropes under tension attached to A1 means two individual interaction forces acting at A1. Please list those two forces and their directions.
I have listed them. If you keep asking the same question you get the same answer.
AM
  • #212
Andrew Mason said:
I have listed them.
You listed two forces on A1:
Centripetal force on A1: 39.5N
Centrifugal force on A1: 79N
Then you claimed that one of them is an inertial force (pseudo force as you call it). But I asked you about the two interaction forces (real forces as you call them) acting on A1. I'm not interested in inertial forces, because we analyze an inertial frame.
So do you now say that the two forces listed above are in fact interaction forces (real forces)?
  • #213
I am not sure what you mean by interacting. There is no force applied by B to A or by A to B in Dale's scenario. If I cut the rope between B and A there will be no change in the way A is rotating assuming that the rope is tethered to some (infinitely massive) fixed point.
But in my scenario they are all interacting in the sense that if I cut any rope, the rotations and motions of all of them will change. If I cut an outer rope, the three tethered masses will, through inertial reconfiguration, rotate about a different centre of mass and that centre of mass will move away from the untethered mass in uniform motion. If I cut a middle rope, the two tethered masses will each rotate about their respective centres of mass and those centres of mass will move away from each other in uniform motion.
AM
  • #214
So you claim the tension in the connecting rope between them is zero and that if you cut the rope, B will miraculously continue to travel in a circle?
  • #215
When did I say that? I gave you the tension as 79N.
Of course not. That would require a centripetal force. When the rope is cut there is none. B will just continue in the same motion that it had when the rope was cut.
AM
  • #216
Right in your last post:
Or did you mean something other than rope tension?
  • #217
I was not talking about "interacting". I was talking about "interaction forces". And I translated it into the term that you tend to use: "real forces".
So I think you know exactly what I mean. You are just playing dumb and derailing:
Andrew Mason said:
...blah...rotations ...blah...motions ...If I cut the rope...blah...
Not what I asked. Simple questions:
Two ropes under tension are attached to A1.
Yes or No?
Two individual interaction forces (real forces as you call them) are acting at A1.
Yes or No?
They are both interaction forces (real forces as you call them)
Yes or No?
  • #218
The tension between A1 and B1 provides the acceleration force on B1 (in my scenario) and the reaction force from B2 to B1. That is what the tension force does. The tension provides both centripetal forces. That accounts fully for its tension.
In Dale's scenario you cannot see the reaction force because he wants to hide from us the body to which the left end of the rope is tied.
AM
  • #219
On the contrary, Dale's scenario is crystal clear. The rope between A and B exerts a real force on both. Do you deny this?
  • #220
I would like to make a comment about the mass on a rope problem.The problem,as presented,describes a thought experiment and a more detailed analysis requires extra knowledge about the relevant parts of the rest of the system.
As an example is the rope rotating untethered in space?If so how can it do that? Could it be tethered and rotating on earth? if so in what sort of circle,horizontal or vertical or somewhere between?For earthbound rotations the two relevant forces on the mass are its weight and the tension in the rope.
Consider the simpler example where there is a single mass.Let this be rotating in a vertical circle and with a speed such at the topmost point of its rotation all of the centripetal force is provided by the weight of the mass,the tension being zero.At this point the action reaction bodies are the mass and the Earth one being pulled down the other being pulled up.Where is the centrifugal force?
  • #221
In your example, the "reaction" centrifugal force would be the upward gravitational pull that the mass exerts on the earth.
  • #222
There are no interaction forces between A1 and B1 in the sense that the tension in the rope between A1 and B1 can only be accounted for by the centripetal forces on A1 and B1 and their respective reaction forces on B2 and A2. The tension is fully accounted for with those forces. You would have to ignore those forces in order to add this mysterious centrifugal force. You can't do that.
So this "centrifugal force" does not add any tension to the rope. Do the math. If you add the centrifugal "forces" you get too much tension. This is hidden from you in Dale's scenario because he won't let you see what is on the other side of the rotating system, that's all.
I know what you mean and why you think there is a centrifugal force. That is not difficult to see.
You have to read carefully what I am saying. Rotational motion is a very difficult area of physics. Don't assume that someone is acting in bad faith because they disagree with you. Not only is that not a very convincing way to persuade the other side, it makes it more difficult for you to want to see and fully understand the contrary view. I argue every day for a living. I can assure you my position is taken in utmost good faith.
Yes or No?
Yes.
Yes or No?
Well there is the rope tension between A1 and A2 and between B1 and B2. That means there is rope tension between B1 and A1 but that is not because B1 is exerting a force on A1. There is no such force. The tensions between B1 and A1, B2 and A2 and between A1 and A2 are fully accounted for by the centripetal forces acting on the masses.
Why not ask why the centrifugal force you say is acting on A1 does not show up in the analysis that I gave of the tensions? If the centrifugal force was real the tension in A1-A2 would have to be 197.5 N. Why is it only 118.5 N?
Yes or No?
The centripetal force is a real force and it produces real acceleration. The centrifugal force on A1 is not a real force.
AM
  • #223
Agreed that it is a "reaction" force .Now consider the mass moving to other positions. 23.36 in the UK and time for beddy byes.Night night sleep tight.
  • #224
Yes. I say that is not correct. The rope exerts a real force on B and a real force on the body to which the post forms a rigid part. It does not exert a force on A. If it exerted a force on A then there would be additional tension in the rope: the centripetal force required to accelerate A and B plus the centrifugal force of B on A. But the tension is only 118.5 N, which is the centripetal force required to accelerate B and A. Why does the centrifugal force not show up in the tension?
I am having difficulty understanding why you are arguing in favour of centrifugal force as a real force. I am certainly not the first person to take the position that there is no such thing as a centrifugal force. Until I read this Wikipedia article on "reactive centrifugal force" I had never heard of the term. I have never found a physics text that talks about centrifugal force as a real force or that makes any distinction between centrifugal reaction force and centrifugal force. Engineering books tend to gloss over the physics and don't count.
As has been pointed out, there is a good discussion of this in "[URL discussion page for the Wikipedia article.
[/URL]
AM
  • #225
Andrew Mason said:
There is if you want to analyse third law pairs of forces.
This is not correct. Here is some course material for you to read on Newton's 3rd law:
http://s3.amazonaws.com/cramster-resource/8637_n_21740.pdf
Example 4.5 (on p2) is a non-isolated system, see the note about the external force. Page 8 also has a second example using Newton's 3rd on a non-isolated system.
Can you find any reference that supports your position that you are required to only analyze 3rd law pairs of forces in isolated systems? Of course, you can find examples of Newton's 3rd law applied to isolated systems, but can you find any reference that says explicitly that it is not possible to use Newton's 3rd law in non-isolated systems?
Andrew Mason said:
I will when you give me all the information needed to analyse it properly.
Already done, as you can see by the fact that I did analyze it properly.
Andrew Mason said:
You say:
"Since the rope is massless, by Newton's 2nd law [itex]F_{A2}+F_{B2}=ma=0[/itex] so by Newton's 3rd law [itex]F_{2A}=-F_{A2}=F_{B2}=-F_{2B}=79.0 N \text{outwards}[/itex]"
Yes, that is all correct.
There are two forces on the rope
[tex]F_{A2}+F_{B2} = 79.0 N \text{inwards} + 79.0 N \text{outwards} = 0[/tex]
And because the rope is massless
[tex]ma=0a=0[/tex]
So Newton's 2nd law is satisfied since [itex]F_{net}=ma[/itex].
The reaction force to [itex]F_{A2}[/itex] is
[tex]F_{2A}=79.0 N \text{outwards}[/tex]
And the reaction force to [itex]F_{B2}[/itex] is
[tex]F_{2B}=79.0 N \text{inwards}[/tex]
So Newton's 3rd law is also satisfied since [itex]F_{A2}=-F_{2A}[/itex] and [itex]F_{B2}=-F_{2B}[/itex]
So that does not in any way violate Newton's laws.
Now that I have demonstrated that Newton's laws are satisfied, do you now recognize that the analysis is correct and that no additional information is needed to completely characterize all of the forces in the system? If not, then you need to specifically identify which force(s) violate which of Newton's laws. This will take the form of specifically identifying an object where the net force on that object is different from ma or identifying a pair of objects where the 3rd law pair is not equal and opposite. Otherwise you need to admit that the analysis is correct.
Andrew Mason said:
The problem is that you are measuring a pseudo force. You are applying Newton's laws in a rotating frame of reference.
No, this is all from an inertial frame. I don't know what would make you believe that I was doing the analysis in the rotating frame. The fictitious forces in a non-inertial frame violate Newton's 3rd law, and all of the forces in my analysis obey Newton's 3rd law. Also, fictitious forces in a non-inertial frame are always proportional to the mass, so since the mass of the rope is 0 the inertial force would also be 0 even if I had made that mistake.
  • #226
If you look at A and B as a single system, then the tension between them is an internal force and thus irrelevant. When you look at them separately, then you must include the tension in your calculations. There are two forces on A: The inward force from one rope and the outward force from the other. (That outward force is what is being called a 'centrifugal' force.)
I am having difficulty understanding why you are arguing in favour of centrifugal force as a real force. I am certainly not the first person to take the position that there is no such thing as a centrifugal force. Until I read this Wikipedia article on "reactive centrifugal force" I had never heard of the term. I have never found a physics text that talks about centrifugal force as a real force. Engineering books gloss over the physics and don't count.
As far as the ridiculous term 'reactive centrifugal force' goes, I've written several posts objecting to its use. Of course, they are using 'centrifugal' in the trivial sense of 'away from the center', so it's really not a big deal.
Personally, except in the context of this thread, I never use the term 'centrifugal force' except when referring to the pseudoforce that appears when analyzing things from a rotating frame. In fact, I'm not even too fond of the term 'centripetal force', since that is often misunderstood. But at least the individual forces that contribute to the 'centripetal force' are 'real', noninertial forces that have actors.
So I am not arguing in favor of the term 'centrifugal force' as a real force, though the 'centrifugal' forces in this thread are real forces. That's a trivial semantic issue. What I am arguing for is the correct application and understanding of Newton's 3rd law and even the meaning of 'centripetal force'; these are concepts that you've repeatedly abused in this thread.
  • #227
No it doesn't. See post 197 where I did a complete analysis without any extra knowledge. The system is not isolated, but I specified that gravity was absent. So all necessary information is provided to answer the questions.
  • #228
If you admit that the rope exerts a real force on B then by Newton's 3rd law B exerts a real force on the rope and this real force is in the opposite direction. Therefore one of those forces is pulling inwards (centripetal) and the other is pulling outwards (centrifugal).
  • #229
Agreed, completely.
  • #230
Dadface is correct. You are trying to avoid the essence of the problem by postulating an unbalanced rotating mass about a perfectly "fixed" point of rotation and treating it as inertial frame of reference. That is IMPOSSIBLE in our present universe according to Newton's laws. You can't just make stuff up. It has to correspond to the real universe.
AM
  • #231
If I stretch an elastic, the tension force in the elastic is a force that is directed toward the centre of the elastic. The direction of the force depends on which side of the centre of mass of the elastic you are looking at. Ergo, the tension is centripetal. Same thing with the rope, just not as obvious.
Just add up the tensions on the ropes. Add up the centripetal forces on the masses. They add up to the tensions. How can the centrifugal force contribute more than this to tension? In the non-inertial frame the centrifugal "force" is needed to explain the tension because you are not observing any centripetal acceleration. In the inertial frame, if you add the centripetal force you get too much tension.
Do you disagree with my figures for tension (ie. 118.5N and 79 N)?
AM
  • #232
The rope can't exert a reaction force unless it has mass. (I thought you said these were massless ropes). You seem to be ignoring the fact that the left end of the rope is connected to another mass. It is the mass that the rope is connected to that exerts the reaction to the pull on the rope.
AM
  • #233
I don't see any claim that the force the rope exerts onto object B is a reaction force. It's object B that exerts an equal and opposing reaction force to the end of the rope (due to the centripetal acceleration).
Going back to what I think is a simpler example is a rocket in space free of any external forces, and using it's engine to maintain a circular path. At the engine, there is a centripetal force exerted on the rocket and a centrifugal force exerted on the ejected fuel. In this case, both forces could be considered reactive.
Trying to get back on what I thought was the topic (and repeating myself), wasn't this thread supposed to be about the validity of the term "reactive centrigufal force"? The wiki articles cite a few references where that term is used, and after discussion at wiki, those involved agreed it was a valid term. The wiki article does need a correction to note that sometimes centripetal forces coexist with reactive centrifugal forces and sometimes they don't, but this doesn't invalidate the terminology.
  • #234
When you look at A and B like that without reference to the centre of rotation or some other inertial frame, you are in a non-inertial frame of reference. In an inertial frame of reference (which may or may not be very close to the post - Dale will not provide that information), you can see that the tension between A and B is entirely a function of B's acceleration and mass. It has nothing to do with A. In other words, if B was pulling on A as a reaction force to the centripetal force on it, A's mass would matter. Since it does not, the reaction force to the centripetal force on B has some other origin (ie. the mass that the post is connected to, which Dale wants to prevent us from knowing anything about).
AM
  • #235
I'm delighted to hear that you don't work in math/physics. The reason why you switched to law is also obvious from this thread.
It is the result of your analysis: Centrifugal force on A1: 79N
It must me a real force, because you analyzed an inertial frame of reference.
  • #236
Nobody asked for a "more detailed analysis". The specific questions posed by DaleSpam can all be answered without any extra knowledge.
  • #237
Who cares? If you want to question if the term is used widely enough to grant a Wikipedia entry, do this on the discussion page of Wikipedia.
Tell this to the Wiki authors. They will tell you that it is perfectly valid to have Wikipedia articles about terms which are used solely/mainly in engineering.
  • #238
Utter nonsense. The frame in which we are analyzing the problem is clearly an inertial frame. A and B are rotating! There are no inertial forces, only real forces.
What forces act on A? The tensions from the two ropes.
What forces act on B? The tension from the second rope.
Since we know the acceleration, we can apply Newton's 2nd law and figure out what those forces are.
And sure, since the ropes are massless, you can consider them as just transmitting the force between bodies. The force that A and B exert on each other is a real force. And of course those forces comply with Newton's 3rd law.
  • #239
Well I think Andrew Mason wants extra knowledge and in order to make a start on the problem I would want extra knowledge.Look at what we have,a rope assembley rotating about one end of the rope and in the absence of gravity and anything else.How can this happen? Is the assembley in deep space,perhaps it is in free fall?There are many questions but just for now perhaps you can tell me how this set up,which is based on a thought experiment,can be brought into the real world.
  • #240
Irrelevant for the questions asked.
It is rotating around the left end in an inertial reference frame.
Dadface said:
There are many questions but just for now perhaps you can tell me how this set up which is based on a thought experiment can be brought into the real world.
  • #241
So are you preferring to keep the question unchanged being based on a thought experiment which has no relevance to the real world?
  • #242
Then you two would both fail freshman physics. No extra knowledge is required to answer the questions asked. If this question were on a freshman physics test and you didn't even start the problem because you asked for extra knowledge then you would not even get partial credit for the question.
By applying an external force to the left end of the rope. The system is not isolated as has been mentioned many times. The details of how you apply that external force do not matter.
It is completely relevant to the real world. Non-isolated systems are analyzed all the time. The only unrealistic part is the "massless rope" approximation.
  • #243
The questions you have asked have no relevance to the solution of the problem within Newtonian mechanics. As for "relevance to the real world" : You could just as well demand information on the color of the mass spheres, because in the real world, they always have some color.
  • #244
Yes, as shown in my analysis. And since the center of mass of the elastic is not the center of rotation then one of those forces is inwards and one is outwards.
Interesting. So you believe that Newton's 3rd law does not apply to massless objects also. Ropes can clearly exert action forces, and if it couldn't exert a reaction force then you could build a reactionless drive. This is clearly absurd, and is just another basic misunderstanding of Newton's laws on your part.
I am still waiting for a reference that Newton's 3rd law does not apply inside non-isolated systems, so now please also provide a reference that Newton's 3rd law does not apply when the traditional massless-rope approximation is used. Because you have a flawed understanding of Newton's laws you are getting a flawed understanding of the problem posed.
  • #245
Law teaches us that ad hominen arguments are not persuasive. You should take that to heart in any debate.
Besides, what does it matter who is making the case here? I am saying that the alleged centrifugal force in either my or Dale's scenario does not appear in the measurements of the tensions. So if it can't be measured it does not agree with reality. So you are talking about a fictitious concept. "It does not make any difference how smart you are, who made the guess, or what his name is – if it disagrees with experiment it is wrong." Richard Feynman.
AM
