MHB Is the Exponential of a Linear Operator Defined?
ryo0071
In class we recently learned that for a linear operator $$T: V \rightarrow V$$ and function $$g(t) = a_0 + a_1t + \dots + a_nt^n$$ one can define the operator $$g(T) = a_0I + a_1T + \dots + a_nT^n$$ (where $$I$$ is the identity transformation). We also recently learned about the exponential of a matrix. My question is that for a linear operator $$T: V \rightarrow V$$ can the operator $$e^T$$ be defined? (For example, like how $$e^A$$ is defined for a matrix $$A$$) (I tried searching for information on it but all I found was information on the exponential of a matrix). Thanks.
Well, you'd probably have the formal definition of
$$e^{T}:= \sum_{j=0}^{\infty} \frac{T^{j}}{j!},$$
where $T^{0}=I$. But whether this makes any sense or not for a particular vector space, I think you might have to decide on a case-by-case basis.
Alternatively, any linear operator can be written as a matrix if you find out how it transforms the basis vectors. Then you could identify the exponential of the operator with the exponential of the corresponding matrix.
Welcome to MHB, ryo0071! :)
The operator $e^T$ is well defined if the corresponding power series is well defined as well and converges.
So let's try it:
$$e^T = I + \frac 1 {2!} T + \frac 1 {3!} T^2 + ...$$
This is a linear combination of linear operators applied to themselves, meaning this is well defined.
Does it converge?
That depends on your T.
Let's pick the identity, then $e^I = I + \frac 1 2 I + \frac 1 {3!} I^2 + ... = e I$.
Looks good doesn't it?
So the answer to your question is yes.
You can define an operator $e^T$ just like you can for a matrix.
Thanks for the quick replies. I figured it probably would be defined like that. How would one test for convergence? (I suppose a better question is how does one define a norm for a linear operator?) And another question would be what part of math would you study things like these (functions of operators)?
ryo0071 said:
Thanks for the quick replies. I guess it probably would be defined like that. How would one test for convergence? (I suppose a better question is how does one define a norm for a linear operator?) And another question would be what part of math would you study things like these (functions of operators)?
The norm for a linear operator is defined here.
As you can see here, it always converges if the vector space has finite dimensions, since any such linear operator can be written as a matrix.
The mathematical branch is functional analysis that studies vector spaces and structures upon them.
Thanks for the links. I look forward to taking a course on functional analysis.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
