- #36
- 24,488
- 15,021
For me the EPR criterion is far from eing well-defined and clear in its meaning. It starts with the assumption that we can measure something without disturbing the object, which is impossible even in the classical realm. So the criterion about "reality" is just an empty phrase at best.
In the quantum realm it's obvious that we cannot measure anything without disturbing it such that the disturbance can be neglected. If we deal with, e.g., an elementary charge (e.g., a proton) and want to measure properties of the proton, e.g., its position we need either another charged particle we can scatter at the proton, and we cannot make the electric charge of this particle smaller than that of the proton, i.e., using the em. force between charges to measure the position, we cannot do that without disturbing the proton considerably, or we use an uncharged particle, like a photon with the well-known consequences discussed by Heisenberg (and in more detail by von Weizsäcker) in the famous "Heisenberg-microscope gedankenexperiment".
The same holds the more for "preparation procedures" defining states of an elementary particle, preparing the particle in a state with a rather well defined position the standard Heisenberg uncertainty principle tells us that its momentum must be rather indetermined and vice versa. So you cannot prepare a particle in a pretty well defined position without disturbing it in such a way that it's momentum stays pretty well defined too.
That's not only a prediction of QT but an experimental fact which is not in accordance with the very assumption in what EPR consider "realistic". So their notion of realism implies that if there's something real, it's not in accordance with our experience, which is however not in accordance with the very fact that we can describe all this experience in very accurate agreement with this very experience by QT. We can even use these quantum-theoretical predictions to manufacture fancy equipment like lasers, semi-conductor based electronics, etc. I'd say the "realism" of QT (i.e., inherent randomness of the outcome of measurements on undetermined observables) is much more in accordance with "reality" than EPR's idea of realism as far as it is well-defined at all.
