Is the formula for conditional expectation valid for multiple random variables?
The discussion centers on the validity of the conditional expectation formula E[Xg(Y)|Y] = g(Y)E[X|Y] for multiple random variables. The proof provided shows that this formula holds for discrete random variables X and Y, using the definition of conditional expectation. However, the question arises whether the formula can be extended to a third variable, Z, leading to E[Xg(Z)|Y]. It is clarified that while one might think to substitute g(Y) with g(Z), the relationship does not hold because Xg(Z) forms a new random variable with its own distribution. Ultimately, the conclusion is that the formula's validity depends on the independence of the variables involved.
jimmy1
[SOLVED] Conditional Expectation
I'm trying to understand the following proof I saw in a book. It says that:
E[Xg(Y)|Y] = g(Y)E[X|Y] where X and Y are discrete random variables and g(Y) is a function of the random variable Y.
Now they give the following proof:
E[Xg(Y)|Y] = \sum_{x}x g(Y) f_{x|y}(x|y)
= g(Y)\sum_{x}x f_{x|y}(x|y)
= g(Y)E[X|Y]
Now, the proof is very simple as they are just using the definition of conditional expectation (ie. E[X|Y]= \sum_{x}x f_{x|y}(x|y)).
But, would this formula also work for say 3 variables? That is, E[Xg(Z)|Y] = g(Z)E[X|Y], where Z is another discrete random variable.
It probably isn't right, but from the above proof I can't immediatley see what's wrong with it, as I'll be just switching the g(Y) with a g(Z), and as the summation in the proof is over x, I can take g(Z) out of the summation and similarly get the result E[Xg(Z)|Y] = g(Z)E[X|Y] ??
No, the proof works because the event {Xg(Y)|Y=y} = {Xg(y)|y} = g(y){X|y}; but the event {Xg(Z)|y} cannot be written similarly, in general.
In general, V = Xg(Z) is a new random variable and has its own distribution and conditional distribution; so the sum is over v.
If X and Z are independent then E[Xg(Z)|y] = E[X|y]E[g(Z)|y].
If Z = h(Y) then E[Xg(h(y))|y] = g(h(y))E[X|y].
Ah yes, that clears things up. Cheers, you've been great help once again!
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
