Is the Potential of a Negatively Charged Conductor Always Negative?
  • Thread starter Thread starter Fips
    Electrostatics
The potential of a negatively charged conductor is not necessarily negative, which can be confusing. While it may seem intuitive that a conductor with a negative charge would have a negative potential, the concept of electric potential is relative. The reference point for measuring potential is crucial, as it can be defined as zero at infinity or another location. This means that a negatively charged conductor can have a positive potential relative to a different point in space. Understanding the context of electric potential is essential for accurate interpretation.
Fips
I was doing some T/F exercises and there was this one that had me confused:
The potential of a negatively charged conductor must be negative
Because it's conductor, i figured all of the conductor would be negatively charged and so it would have a negative potential, but apparently this statement is false. What am i missing?
Thanks
Ahhh I get it now :P tricky setence tho, thanks!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
