- #71
ghwellsjr
- 150
There are two kinds of tests that the laws of physics must pass in order to adhere to a principle of relativity. The first is that the equations must be able to undergo a transformation and remain the same as they were before. This is a purely mathematical operation but it does require a specific transformation. The second test is purely experimental. The relevant features of the law under question must not provide a means for an isolated observer to determine his velocity in an absolute sense.
Prior to Maxwell the Principle of Relativity used the Galilean Transformation to determine if any particular law of physics adhered to the PoR. All mechanical laws did. But Maxwell's equations did not, which lead Maxwell to conclude that the PoR was not true and a test could indicate this. But all tests, especially MMX, did not support this conclusion.
So along comes Lorentz who discovered a different Transformation for the PoR that would support Maxwell's equations. But it didn't support all the other laws of mechanics so these were modified to make everything adhere to the new PoR under LT.
But everyone still assumed that there was a preferred state of rest, primarily because it never occurred to them that time could be relative. This was embodied in LET. Notice that the equations of LET do not change when going through the LT and there is no experiment that can discover velocity in an absolute sense. So LET adheres to the two requirements of the PoR based on LT.
Along comes Einstein who points out that you could take the defining characteristic of the ether frame, the one-way speed of light, and assume it to be true for any reference frame, and this results in time (and space) being relative.
It is clear that both SR and LET use the same transformation as the requirement to fulfill the mathematical aspects of the PoR. Einstein called this his first postulate. Whether or not Lorentz explicitly used the same terminology, the import is the same. Lorentz then assumed that the one-way speed of light was c only in the ether rest state, whether or not he explicitly stated this as a second postulate. Einstein's explicit second postulate ran counter to this stating that this was true in every inertial frame.
It's the fact that both of these two second "postulates" are not based on measurement or experiment that makes both LET and SR remain viable while still adhering to the new principle of relativity base on the Lorentz Transformation.
