Is the Set of Points (x, y, 3x + 2y) a Subspace of a Homogeneous System?
Ryker
Suppose you have points of a specific form, say (x, y, 3x + 2y). Show that this set of points is a solution to a homogeneous system of linear equations, hence a subspace.
I'm wondering how one is able to go about this. Here's my try, but I'm not sure I'm going about this the right way. I assumed vectors u = (x1, y1, 3x1 + 2y1) and v = (x2, y2, 3x2 + 2y2) are two solutions. Next, I said any linear combination of them, say, tu + sv is also a solution to Ax = 0, where x is the solution vector. Then I just expanded the terms and showed that indeed any solution to Ax = 0 as a linear combination of u and v still retains the form (x, y, 3x + 2y).
Is this the proper way of doing this or is there another one? Should I have perhaps instead written down, for example, a1x + a2y + a3(3x + 2y) = 0, expanded it to (a1 + 3a3)x + (a2+2a3)y = 0, and then resolved this equation to show that the solutions for a's involve parameters?
the points given by (x, y, 3x + 2y) represents a plane through the origin and satisfies 3x + 2y - z = 0 which is a homogenous linear equation
Hmm, yeah, you're right, I didn't think of it that way. But are you sure this is the proper way of formally proving it?
edit: Looking at it again, your solution would then be similar to the second one I proposed, right? I mean, whereas I would get parameters for a's, they could correspond to 3, 2 and -1 in your solution, as well as to multiple other coefficient solutions, such as 6, 4, -2 etc. Could you perhaps elaborate on that a bit?
And could anyone comment on my proposed first solution? Is it wrong, or just another way of going about it?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
