Is the Twin Paradox Truly Unresolvable from Speedo's Perspective?
In summary, Lorentz's theory states that time is always dilated. This means that even when two individuals, like Speedo and Goslo, start off at the same age, if one of them travels at high speeds, they will age slower than the other. This is known as the "twin paradox". However, from Speedo's point of view, both he and Goslo would see each other's clock ticking slower than their own for half of the trip and faster for the other half. This is due to the time it takes for images to propagate. When Speedo returns to Earth, he would be much younger than Goslo, as seen from Goslo's perspective. This is because Goslo saw Speedo's
  • #36
AntonL said:
A & B sync their clocks:
1) A sees B depart at some high speed and return, A aged and B remained young
but also at the same time
2) B sees A depart at some high speed and return, B aged and A remained young
So whoever ages depends into which spaceship you place the reference frame.
Now if above is all gibberish then SR is to blame. Sorry I rephrase: The science must be correct it is just that I do not understand SR. Maybe someone can give me a nice logical explanation and proof to explain to me which clock actually slowed down when A and B meet again.
I already did that in post #4. Did you read it? Do you understand it?
Please note that my explanation is not based on SR, it is based only on the Principle of Relativity, Einstein's first postulate, but not on his second postulate. His second postulate is also needed in order to construct a Frame of Reference. So even without resorting to a reference frame, you can still prove unambiguously which twin ages less and which twin ages more. You can't blame SR or your lack of knowledge of SR for the fact that we can determine the age difference between the two twins in either of your two scenarios.
You do realize that you have described two different scenarios even though you said "but at the same time", don't you? What matters is which twin is the one that "returns", that is, which one fires his rockets and turns around. If B is the one that does the returning as you said in scenario 1, then B ages less. If A is the one that does the returning as you said in scenario 2, then A is the one that ages less. As I pointed out in post #4, whichever twin is the one that returns is the one that immediately sees the image of the other ones clock go from ticking slow to ticking fast while the other twin does not see that until much later.
Like I said in post #4, it's really very simple.
  • #37
Michio Cuckoo said:
According to Lorentz, time is always dilated.
So think of two twins, Speedo and Goslo.
- Goslo stays on Earth and drinks tea.
- Speedo gets into a rocket, zooms off into outer space and zooms back.
Imagine YOU are Speedo. You zoom off, and when you return to Earth, you find that Goslo is 20 years older than you.
Here's a related "paradox" in good old planar Euclidean geometry.
Suppose you are walking along a road and you come to a second road that intersects the first at an angle theta (for definiteness, assume that it is 8.05°). Suppose that each road has distance markers, one every meter.
While you are traveling on your road, you see that when you pass marker number 100 on your road, you look straight to your left and see marker number 101 on the other road. When you pass marker number 200, you see marker number 202 on the other. Etc. When you get to marker number 500, the other road makes a turn toward your road. You continue to compare markers: when you pass marker number 600, the corresponding marker on the other road is 606, etc. Finally, when you reach marker number 1000, the two roads come together again, and the second road shows distance marker 1010.
Letting N be the marker number on your road, and N' be the marker number on the other road, we can show geometrically that the formula relating the two distances is:
ΔN' = ΔN √(1+m2)
where m is the slope (tangent of 8.05°), which is .1414. For our choice of m, this turns out to be:
ΔN' = 1.01 ΔN
This is not too surprising: a straight line is the shortest distance between two points, so it makes sense that the "bent" road is slightly longer than the "straight" road. But now let's look at things from the point of view of a traveler on the "bent" road. When he comes to marker number 101, he looks straight to his right and sees that the corresponding marker on your road is not 100, but 102. When he comes to maker number 202, he looks straight to his right and he sees, not marker number 200, but marker number 204. The relationship that he notices is just the opposite of the pattern you noticed. Instead of
ΔN' = 1.01 ΔN
he finds
ΔN = 1.01 ΔN'
When the traveler on the "bent" road comes to the bend, which is at marker number 505, he looks straight to his right, and sees marker number 510 on your road. So far, from the point of view of the other traveler, it looks like your road is going to be the longer one, not his. But then he turns the corner...
As he is turning, he is looking to his right at your road, and he sees distance markers on your road moving past. Before the turn, he sees marker number 510, but then as he turns, he sees to his right distance markers number 509, 508, ..., 500, 499, ... 490. Immediately after making the turn, when he looks to his right, he sees marker number 490 on your road. From then on, he sees your numbers increase by the same formula as before:
ΔN = 1.01 ΔN'
So when he travels another 505 meters (for a total of 1010 meters counting both legs of the trip), he sees your road's markers advance by 510 meters, for a total of 490 + 510 = 1000.
So, the moral of the story is that only the "straight-line" traveler can use the formula
ΔN' = ∫dN √(1+m2)
to compute the length of another road. A traveler along a "bent" road will get the wrong answer using that formula, unless he takes into account the effects of turning a corner.
The twin paradox is very similar. Any inertialtraveler can use the formula
tau = ∫√(1-(v/c)2) dt
to compute the amount of aging for another traveler. But a noninertial traveler cannot use that formula, unless he takes into account the effects of turning around.
Proper time in SR is analogous to distance along a path in Euclidean geometry.
Relative speed in SR is analogous to relative slope in Euclidean geometry.
Changing velocity in SR is analogous to turning a corner in Euclidean geometry.
  • #38
stevendaryl said:
Here's a related "paradox" in good old planar Euclidean geometry...
Excellent analogy!
  • #39
Stevendaryl, isn't your explanation identical to the one Jonathan Scott presented in post #2? And I have the same complaint about yours as I did about his: it doesn't address the question that Michio Cuckoo asked:
Michio Cuckoo said:
Discuss this but only consider Speedo's point of view. Because if you are Speedo, what would you see?
You talk about what your two travelers would see in your analogy but it isn't at all like anything that Speedo (and Goslo) can see, is it? What they see is what I described in post #4 and is all you need to show that Speedo ages less than Goslo, don't you agree?
  • #40
I agree that the Doppler shift explanation explains the difference in the two ages, but I think it leaves a bit of a puzzle as to why can the inertial twin use the formula:
τ= ∫√(1-(v/c)2 dt
to compute the age τ of the noninertial twin, but the noninertial twin cannot use that formula to compute the age of the inertial twin. Why not? After all, the noninertial traveler is only noninertial for a tiny moment; how can that tiny moment make such a big difference?
That formula for proper time is exactly analogous to the formula for path length in planar Euclidean geometry:
L = ∫√(1+m2 dx
Trying to apply the time dilation formula to compare the ages of the twins is very much like trying to apply the length formula to compare the lengths of two roads.
  • #41
IMHO: That's a fair criticism, but there's something else going on that's also worth noting:
Online discussions of the twin paradox tend to veer back and forth between "What do we see?" and "How can that be?". The former is Michio Cuckoo's original question, best answered by your post #4 and Dopplerish explanations; the latter is often better answered with a spacetime diagram analysis, and both Jonathan Scott's and Stevendaryl's answers are of that flavor.
  • #42
τ= ∫√(1-(v/c)2 dt
Anyone can calculate the proper length of any worldline if they know it.
Yes, it kinks the worldline and reduces its proper length.
The proper length uses Lorentzian distance, but otherwise the two calculations are the same.
See https://www.physicsforums.com/showthread.php?t=587949&page=8&post=126
(the link isn't right so you need to scroll down the page)
  • #43
τ= ∫√(1-(v/c)2 dt
Of course the noninertial twin can use that formula, just like you can use the formula or anybody else can, we just have to use it from any arbitrary inertial Frame of Reference. The only reason why you say that the inertial twin can use the formula is because you have bought into the false notion that the twins can only use a frame in which they are at rest which leads to another false notion that the noninertial twin must use a noninertial reference frame.
As I pointed out in post #13, we can use a frame in which Goslo remains at rest throughout the scenario and all the time dilation falls on Speedo making the explanation trivially simple. But we could also use a frame in which Speedo is at rest during the first half of the trip in which all the time dilation falls on Goslo. But during the second half of the trip, Speedo will have even more time dilation while Goslo's continues the same. However, this inertial frame is more complicated to analyze because we have to calculate both twins' time dilation to see which one ends up with more.
Please don't get me wrong, I'm not saying that noninertial frames are invalid, I'm just saying that they are very complicated to analyze and don't offer anything more than any inertial frame or no frame at all (Doppler analysis) and most significantly, they don't provide the twins with any more insight into what is happening to the other twin--none whatsoever--there is no advantage to using a noninertial frame except to demonstrate the mathematical prowess of the presenter.
  • #44
ghwellsjr said:
My explanation is not based on SR, it is based only on the Principle of Relativity, Einstein's first postulate, but not on his second postulate. His second postulate is also needed in order to construct a Frame of Reference. So even without resorting to a reference frame, you can still prove unambiguously which twin ages less and which twin ages more.
Your explanation tacitly invokes the light-speed postulate, and also a frame of reference. Remember, Galilean relativity also satisfies the principle of relativity, but it doesn't imply unequal aging of the twins. So the unequal aging can't be explainable in terms of ONLY the principle of relativity. When you talk about Doppler effects that each twin will see, you are tacitly assuming things about the propagation of light being unaffected by the motion of the source, and so on, things that are tantamount to the light-speed postulate, in addition to the principle of inertia (i.e., the principle of relativity), and these things collectively are sufficient to construct inertial coordinate systems. You can't get any of the unique effects of special relativity (as distinct from Galilean relativity) purely from the relativity postulate alone. The light-speed postulate (or something equivalent to it) is necessary.
  • #45
Well, that's the issue: why must it be an inertial frame of reference? Why can't it be a "piecewise inertial" frame of reference? That is, why can't you use
τ= ∫√(1-(v/c)2 dt
where t is proper time for the "traveling" twin, and v is the speed of the "stay-at-home" twin relative to the instantaneous rest frame of the traveling twin? You can't because there are pieces of the worldline of the stay-at-home twin that are left unaccounted for. (In the Euclidean analog, the problem is that there are pieces of the path of the "straight" road that are counted twice by the corresponding formula for length).
  • #46
DaleSpam said:
This is not true. All inertial frames will agree which is younger when they return. Once you have completely specified the problem in anyone inertial frame you can determine what happens in any other ... Compare the results.
really?
and
No I don't understand post 4
Nor have you seemed to understood the problem I posed. Let's reformulate the "Which twin aged?" problem.
Let each twin be in a separate spaceship A and B orbiting a planet C in circular orbits. We assume the planet to be non rotating. A orbits clockwise and B orbits anticlockwise. Both A and B clocks as seen from C are ticking at the same rate but at a reduced rate to that of C due to the orbit velocity and some increased rate due to gravitational effects as compared to if they where stationary on planet C. each time A and B pass (twice per orbit) the clocks have the same time. The GPS satellites pride themselves as proving SR as the clocks are corrected for both gravitational and velocity aspects as described.
Lets go into spaceship A and set our reference frame in this spaceship A. That is A is now experienced as stationary an B is moving relative to A and planet C is orbiting around A. Please describe what we expect from clock B now relative to A.
As I said I am totally confused as I cannot find a logical pleasing answer.
  • #47
You are making it difficult for yourself. Firstly, the time on any clock, irrespective of what is going on elsewhere is given by a simple formula which relies *only* on information about the worldline of the clock in question. So if you want to compare the elapsed time for different clocks, just calculate the proper time of the worldline between the events for each worldline, then compare them. As easy as measuring shoes.
  • #48
If your problem involves orbits, then you can't solve it using Special Relativity.
  • #49
AntonL said:
really?
Really, really. It is a pretty typical homework problem. I recommend working through it for your own instruction.
Suppose in some inertial frame that A leaves Earth at v=.6c and reaches a planet 3 ly away in a time of 5 y and then immediately turns around at v=.6c returning 10 y later, while B stayed at Earth the whole time. Calculate the age of the twins at the reunion:
1) in the frame where the Earth is at rest the whole time
2) in a frame where the Earth is moving at .333 c the whole time
  • #50
Let each twin be in a separate spaceship A and B orbiting a planet C in circular orbits...
Unfortunately, that reformulated problem is waaaay harder than the flat spacetime problem in the original formulation of the twin paradox. Your best bet is to work through post 4 and the FAQ at http://www.physics.adelaide.edu.au/~dkoks/Faq/Relativity/SR/TwinParadox/twin_paradox.html until you have nailed the flat spacetime problem, then think about the problem of two traveling twins and one stay-at-home twin, still in flat spacetime with no gravity, no circular orbits, travel in a straight line, ...
  • #51
This is true, but there is an invariant proper interval in GR, so the calculation is similar, but using a different metric from the Minkowski.
  • #52
τ= ∫√(1-(v/c)2 dt
That formula is defined for an inertial Frame of Reference. Its definition is not applicable to a noninertial frame. If you want to come up with your own definition of a noninertial frame, then you have to be precise about what you mean and you have to come up with your own formula for calculating whatever you want to calculate.
But again, my complaint about your analogy is that when you say that one traveler can look over at the other one and see how far he has progressed, it gives the impression that Speedo can look over at Goslo and see how far he has progressed, meaning, of course, where he is at any particular time, but he can't do that. No explanation provided by SR, either with inertial or noninertial frames can do that. All that these "explanations" are doing is echoing back the definitions that the frames employed in the first place. They don't provide any new information to the twins. It's nothing more than saying, "I will call the time on Goslo's clock just before Speedo turns around tt- and the time just after Speedo turns around tt+ and then subtracting the times and saying that Goslo's clock did something weird when Speedo turned around" (for a noninertial frame). Or saying, "the time on Goslo's clock when Speedo turned around was tt" (for an inertial frame). They are both based on arbitrary definitions and none is more right or wrong or more enlightining to either twin.
We already dissuaded Michio Cuckoo from using insta-beams (see his post #7) and now you have just reintroduced them in your analogy. That's my complaint.
  • #53
Normal Doppler, where there is a medium such as air for sound, is not relativistic, meaning that two observers don't hear the same thing coming from the other one because we have to take into account their relative speed in the medium.
If we assume the Principle of Relativity for light, we are assuming that what each twin sees of the other one is symmetrical and not dependent on their relative speed in any medium. It can be easily demonstrated that two inertial observer with a relative motion between them, traveling along the same line will see a Doppler factor while approaching that is the reciprocal of the Doppler factor while receding. This by itself is all that is necessary to show that if one of those twins remains inertial while the other one travels away at some constant speed creating a constant Doppler factor less than one and then turns around and approaches at that same constant speed, he will observe a Doppler factor that is the inverse of the first one, a number greater than one. Let's say that the return Doppler factor is N, a number greater than one and the departing Doppler factor is 1/N. We take the average of these two numbers to get the total ratio of their accumulated ages. This number will always be greater than one and in fact is equal to gamma. Speedo will watch Goslo's clock constantly advancing during his entire trip, first slower then his own and then at turn-around faster than his own and when they meet, Goslo's clock will have advance gamma times the amount his own clock has advanced. This is exactly addressing the question that Michio Cuckoo asked in his first post.
Remember, Einstein's second postulate is that the propagation of light is c, meaning that the unmeasurable one-way time is equal to one-half of the round-trip time and the Doppler analysis does not require that or depend on that in any way. In fact it works the same in any frame even in those for which the two one-way times for a round trip propagation of light are not equal. In other words, it is making no statement about the synchronization of the clocks of the two twins while they are separated, only the final outcome of the time difference when they reunite.
  • #54
Usually, when people discuss the Twin Paradox, one of the twins does all the traveling while the other one stays home. Since you didn't explicitly state in your scenario in post #34 that they were in symmetrical orbits around a planet (you didn't even say there was a planet) and since you called them twins and since the subject of this thread is the Twin Paradox, I assumed that you were presenting Twin Paradox scenarios. But now that you have provided further details, I see that you are not asking about the Twin Paradox but something for which there is not even an apparent paradox.
Twin A will observe that twin B's clock advances more slowly than his own during most of twin B's orbit around the planet, assuming a transparent planet, and then he will see twin B's clock advancing faster than his own so that when twin B gets back to twin A, their clocks display exactly the same time. Why is this confusing to you?
  • #55
Analogy: suppost you are looking directly at the Moon and you then turn your head sideways through 90° in one second. That brief moment when your head is non-inertial causes the moon to move over one third of a million miles in one second relative to your head's "frame of reference". Sometimes a small change can have a big effect.
  • #56
And as everyone knows, the sun travels many millions of miles per hour in its orbit around the Earth relative to the Earth's noninertial rest frame.
  • #57
But this is a thought experiment assuming the Earth is stationary, I think. Plus, as predicted by General Relativity, the Earth's orbit is actually an inertial FoR.
  • #58
Yes but that's due to rotation, yeah. If the rotational and orbital periods were the same (like the OP's rocket around his planet) it would be the whole cosmos revolving around a stationary earth-sol systems at many times c, even better huh?.
  • #59
I was talking about earth, not its orbit.
  • #60
What do you mean? I meant the Earth itself, which is an inertial reference frame, but an observer actually on the Earth, due to gravity and rotation, is in a non-inertial reference frame.
  • #61
Not true. There are other ways that light could propagate, such as a classical (c+v) ballistic theory, which is perfectly relativistic, not reliant on any speed relative to a supposed medium, and yet such a theory wouldn't imply the time dilation effects and asymmetrical aging of special relativity, because the speed of light would not be independent of the speed of the source. (Try working out your prediction for the twins' ages based on a Newtonian ballistic theory of light, in which "what each twin sees of the other one is symmetrical and not dependent on their relative speed in any medium". You won't get any asymmetrical aging.) Only by combining BOTH of those conditions, i.e., the principle of relativity (classically associated with ballistic theories) AND the principle of source-independence (classically associated with wave theories) do you get the effects of special relativity. The latter is the light-speed postulate, which you are tacitly assuming.
  • #62
Why are we "tactically assuming" this? Experiments confirm it.
  • #63
Because of the big distance. In an accelerated frame time flows at different rates along the acceleration direction. The further away along that line, the bigger the difference in clock rates.
See:
https://www.physicsforums.com/showpost.php?p=3920630&postcount=32
  • #64
i think this is a much simpler thought experiment:
imagine you have two clocks C1, C2 in an inertial frame and showing the same time. a third clock C3 moves uniformly on a trajectory parallel to the line made by C1, C2. at time 0, C3 crosses the point of shortest distance to C1 on its trajectory. all the clocks read 0 at this point. After some time t2, an observer at C2 sees C3 crossing and reads off the time t3 on C3 and he finds t3<t2.
now consider the inertial frame associated with C3. would an observer traveling with C3 in that frame see that t3>t2 when C3 crosses C2?
  • #65
I was talking about the approximately 24-hour rotation of the earth, not the annual orbital period of the Earth which would produce a speed for the sun of only a very small fraction of a million miles per hour. And just like an observer on the surface of the earth, the Earth itself can define a noninertial reference frame. It would be noninertial even without gravity. Rotation is all that I'm considering. In that noninertial frame, the sun travels at millions of miles per hour.
And as Austin0 pointed out, if we include stars beyond our sun, they are traveling at many times c.
  • #66
Well, we don't live in a world where the ballistic theory of light is true and you are correct that Einstein did include the principle of source-independence in his second postulate but you have ignored the salient point of his second postulate which I specifically addressed at the end of the post you quoted:
So, yes, I am taking for granted the source-independence of light because that part of Einstein's second postulate is measurable and proven to be true.
So now would you agree that based solely on Einstein's first postulate of the Principle of Relativity and the principle of the source-independence of light but ignoring the rest of Einstein's second postulate and without establishing any frame of reference, we can determine that the Doppler factors for approaching and retreating at the same relative speed are reciprocals of one another and from this alone we can determine that Goslo ages more than Speedo by the factor gamma? And would you agree that this analysis directly answers Michio Cuckoo's question in post #1?
  • #67
Yes, he considers that clocks C1 and C2 are not synchronised by the amount t3-t2.
He also considers C1 and C2 are both ticking too slowly (equally) compared to C3.
He sees both C1 and C3 saying t=0 when they pass because the difference in their tick rates integrates to t3-t2 over the journey from C1 to C2.
  • #68
ghwellsjr said:
That formula is defined for an inertial Frame of Reference. Its definition is not applicable to a noninertial frame..
Uh, that's what I said. The point of my post was to explain what goes
wrong if you try to use it in a noninertial frame, to give a feel for why it doesn't work in noninertial frames.
It's almost never the case that we understand what's going on in the world
by just looking. Looking gives us information which we then have to piece
together to get the complete story. You can certainly, after the fact,
compute the quantity:
T_1(t) = the age of twin 1 at the time twin 2 has age t, as measured in the
frame in which twin 2 is instantaneously at rest.
and
T_2(s) = the age of twin 2 at the time twin 1 has age s, as measured in
the frame in which twin 1 is instantaneously at rest.
Then these quantities will satisfy
dT_1/dt = square-root(1-(v/c)2)
where v is the speed of twin 1 as measured in the frame in which twin 2 is at rest, and
dT_2/dt = square-root(1-(v/c)2)
where v is the speed of twin 2 as measured in the frame in which twin 1 is at rest,
except during times of acceleration.
  • #69
That's exactly the point of the Euclidean analogy that I (and others) gave.
  • #70
Fair enough. The point of the analogy still holds.
Still please note that if the Earth were replaced by a point (which won't happen, but for the sake of example let's assume it did,) that point would be a completely inertial reference frame, despite the fact that it's orbiting the Sun, one of the primary postulates of General Relativity.
Also true. The point of the analogy also holds.
I feel like doubting this cos velocities don't add in the same sense as classic relativity tells us it does. I'd have to claim that you'd get near c.
9K
