MHB Is the Uptake Equation Different When $k_2 = 0$?
  • Thread starter Thread starter Dustinsfl
When $k_2 = 0$, the uptake equation significantly alters the dynamics of the system, necessitating a re-evaluation of the model. The differential equations governing the concentrations of substrates, enzymes, and products must be adjusted to reflect this change, particularly in the context of the Michaelis-Menten kinetics. The non-dimensionalization process also requires modification to accommodate the absence of the second rate constant. The resulting uptake equation indicates that the Michaelis-Menten rate of uptake simplifies under these conditions, leading to a new formulation for the rate. The discussion concludes with a request for assistance in plotting the modified uptake dynamics in Mathematica.
Dustinsfl
The question I have is: when $k_2 = 0$ sketch the uptake $r(u)$ as a function of $u$ and compare it with the Michaelis-Menten uptake.
If $k_2 = 0$, wouldn't that change everything significantly? Does that mean re-do everything with $k_2 = 0$.
Is the Michaelis-Menten uptake just Michaelis constant?$$
S + E \underset{k_{-1}}{\overset{k_1}{\rightleftharpoons}} C_1 \xrightarrow{k_2} E + P,
S + C_1 \underset{k_{-3}}{\overset{k_3}{\rightleftharpoons}} C_2\xrightarrow{k_4} C_1 + P
Let $s = $, $e = [E]$, $c_1 = C_1$, $c_2 = [C_2]$, and $p = [P]$.
Then by the Law of Mass action, we can write down the differential equation model as:
\begin{align}
\frac{ds}{dt} =& -k_1es + (k_{-1} - k_3s)c_1 + k_{-3}c_2,\\
\frac{dc_1}{dt} =& k_1se - (k_{-1} + k_2 + k_3s)c_1 + (k_{-3} + k_4)c_2,\\
\frac{dc_2}{dt} =& k_3sc_1 - (k_{-3} + k_4)c_2,\\
\frac{de}{dt} =& -k_1se + (k_{-1} + k_2)c_1,\\
\frac{dp}{dt} =& k_2c_2 + k_4c_2
\end{align}
The initial conditions for the differential equation model are
s(0) = s_0,\quad e(0) = e_0,\quad c_1(0) = c_2(0) = p(0) = 0.
Since the enzyme is the catalyst, the enzyme is conserved by adding equations 2, 3, and 4.
\frac{de}{dt} + \frac{dc_1}{dt} + \frac{dc_2}{dt} = 0\Rightarrow e(t) + c_1(t) + c_2(t) = e_0
Then $e(t) = e_0 - c_1(t) - c_2(t)$.
Since $dp/dt$ is uncoupled, we can directly solve for $p(t)$.
\int dp = \int (k_2c_1 + k_4c_2)dt\Rightarrow p(t) = k_2\int c_1dt + k_4\int c_2dt
The only equations left to solve for are equations 1, 2, and 3 which are
\begin{align}
\frac{ds}{dt} =& -k_1e_0s + (k_{-1} + k_1s - k_3s)c_1 + (k_1s + k_{-3})c_2,\notag\\
\frac{dc_1}{dt} =& k_1e_0s - (k_{-1} + k_2 +k_1s +k_3s)c_1 + (k_{-3} + k_4 - k_1s)c_2,\notag\\
\frac{dc_2}{dt} =& k_3sc_1 - (k_{-3} + k_4)c_2,\notag
\end{align}
after substituting $e(t) = e_0 - c_1(t) - c_2(t)$.
By making the substitutions
\begin{alignat*}{4}
\tau &= k_1e_0t, & u &= \frac{s}{s_0}, & v_1 &= \frac{c_1}{e_0}, & v_2 &= \frac{c_2}{e_0},\notag\\
a_1 &= \frac{k_{-1}}{k_1s_0}, &\quad a_2 &= \frac{k_2}{k_1s_0}, &\quad a_3 &= \frac{k_3}{k_1}, &\quad a_4 &= \frac{k_{-3}}{k_1s_0},\notag\\
a_5 &= \frac{k_4}{k_1s_0}, & \epsilon &= \frac{e_0}{s_0}
\end{alignat*}
we can non-dimensionalize then model as
\begin{align}
\frac{du}{d\tau} =& -u + (u -a_3u + a_1)v_1 + (a_4 + u)v_2 = f(u,v_1,v_2),\notag\\
\epsilon\frac{dv_1}{d\tau} =& u - (u + a_3u + a_1 + a_2)v_1 +(a_4 + a_5 - u)v_2 = g_1(u,v_1,v_2),\notag\\
\epsilon\frac{dv_2}{d\tau} =& a_3uv_1 - (a_4 + a_5)v_2 = g_2(u,v_1,v_2).\notag
\end{align}
The initial conditions for the dimensionless model are
u(0) = 1,\quad v_1(0) = v_2(0) = 0.
Just as in class this model is a single perturbation for $0 < \epsilon\ll 1$.
Solving for $v_1$ and $v_2$, we obtain
v_1 = \frac{u}{a_1 + a_2 + u + a_3u^2(a_4 + a_5)^{-1}} \quad\text{and}\quad v_2 = \frac{a_3uv_1}{a_4 + a_5}.
Then
f(u,v_1(u),v_2(u)) = \frac{du}{d\tau} = -u\frac{a_2 + a_3a_5u(a_4 + a_5)^-1}{a_1 + a_2 + u + a_3u^2(a_4 + a_5)^{-1}} = -r(u)
is the uptake equation for $u$.
Let$A = a_2$, $B = a_3a_5(a_4 + a_5)^{-1}$, $C = a_1 + a_2$, and $D = a_3(a_4 + a_5)^{-1}$.
Then
\frac{du}{d\tau} = -r(u) = -u\frac{A + Bu}{C + u + Du^2}.
Mathematics news on Phys.org
Would it be a simply substitution or would the non-dimensionalization have to be re-worked?
S + E \underset{k_{-1}}{\overset{k_1}{\rightleftharpoons}} C_1,
\begin{align}
\frac{dc_1}{dt} =& k_1se - (k_{-1} + 0 + k_3s)c_1 + (k_{-3} + k_4)c_2,\\
\frac{de}{dt} =& -k_1se + (k_{-1} + 0)c_1,\\
\frac{dp}{dt} =& 0 + k_4c_2
\end{align}
\int dp = \int (0 + k_4c_2)dt\Rightarrow p(t) = 0 + k_4\int c_2dt
\begin{align}
\frac{dc_1}{dt} =& k_1e_0s - (k_{-1} + 0 +k_1s +k_3s)c_1 + (k_{-3} + k_4 - k_1s)c_2,\notag\\
\end{align}
\begin{alignat*}{4}
a_1 &= \frac{k_{-1}}{k_1s_0}, &\quad a_2 &= \frac{0}{k_1s_0}=0, &\quad a_3 &= \frac{k_3}{k_1}, &\quad a_4 &= \frac{k_{-3}}{k_1s_0},\notag\\
\end{alignat*}
\begin{align}
\epsilon\frac{dv_1}{d\tau} =& u - (u + a_3u + a_1 + 0)v_1 +(a_4 + a_5 - u)v_2 = g_1(u,v_1,v_2),\notag\\
\end{align}
v_1 = \frac{u}{a_1 + 0 + u + a_3u^2(a_4 + a_5)^{-1}} \quad\text{and}\quad v_2 = \frac{a_3uv_1}{a_4 + a_5}.
Then
f(u,v_1(u),v_2(u)) = \frac{du}{d\tau} = -u\frac{0 + a_3a_5u(a_4 + a_5)^-1}{a_1 + 0 + u + a_3u^2(a_4 + a_5)^{-1}} = -r(u)
Let$A = a_2=0$, $B = a_3a_5(a_4 + a_5)^{-1}$, $C = a_1 + a_2$, and $D = a_3(a_4 + a_5)^{-1}$.
Then
\frac{du}{d\tau} = -r(u) = -u\frac{Bu}{C + u + Du^2}.
So the Michaelis-Menten rate of uptake is
R_0 = \frac{Q_{s_0}}{K_m+s_0}
where $K_m=\dfrac{k_{-1}+k_2}{k_1}$ and $Q_{s_0}=k_2e_0s_0$
Q is the max velocity K_m is the Michaelis constant.
How can I plot this in Mathematica?
Re: Michaelis-Menten uptake
​Solved
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
