Is there a common measurement term for joules/volume/°C?
  • Thread starter Thread starter some bloke
    Measurement Term
The discussion centers on finding a common measurement term for thermal energy storage that combines joules, volume, and temperature. The focus is on converting specific heat capacity from a mass-based to a volume-based measurement to maximize energy storage in a thermal store. Hydrogen is noted for its high specific heat capacity, but water is favored for its practicality, cost-effectiveness, and efficiency in heat exchange. The concept of volumetric heat capacity is introduced as a relevant measurement term, combining density and specific heat capacity. Overall, the conversation emphasizes that the highest specific heat capacity alone does not guarantee maximum usable energy for practical applications.
some bloke
TL;DR Summary
I am looking to find the highest thermal energy density per volume, for a mass heater project.
I need to work out the maximum thermal energy which can be stored within an area, and to do this I need to convert the specific heat capacity (which measures by mass) to measure instead by volume. Is there a common measurement term I can search for (in the same way as I might search "specific heat capacity of _X_") that I can look for?
Currently I'm finding that hydrogen has the highest SHC, but I feel it might be difficult to make something out of it!
The goal is to be able to store as much energy as possible in a mass, and then for it to reduce as little as possible whilst it heats the water I run through it! I know that it will take longer to heat a mass with more SHC, but that's not an issue!
Also, Am I correct that I need the highest specific heat capacity to store the maximum energy for this project?
Can you use a phase change? There are eutectic salts that can be tuned to the transition temperature you want. They store a lot of energy.
Otherwise water has a very high heat capacity.
Likes sophiecentaur
What you are talking about is called a thermal store. Water is generally used because (i) it has a high specific heat capacity (ii) it is easy to get heat into the store (just pump in hot water) (iii) heat exchangers for getting heat out of the store work best with fluids (iii) it is cheap. Even if you find something that is better at a combination of (i), (ii) and (iii), water will almost always win hands down on (iii) (the exception being if you want a temperature out that is near boiling).
No, you can store the maximum energy with the highest heat capacity (i.e. specific heat capacity x mass). However what you need is the maximum usable energy: if you want a mug of boiling water, 1MJ of heat energy at 50°C is not a lot of use to you.
So design parameters for a thermal store are more than just 'store as much thermal energy as possible'.
Sounds like you are defining volumetric heat capacity.
@onatirec beat me to it.
##density~ \frac {lbm} {ft^3} * sp~ heat~ \frac{Btu} {lbm~-~F} = \frac {Btu} {ft^3 ~-~F}##
Sorry for the units, a lifetime habit
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
