- #106
PeterDonis
Mentor
- 46,643
- 23,194
Buckethead said:Assume an empty universe (no stress-energy anywhere) and you have two rings with a distance between them and one is spinning relative to the other. Will either feel any forces of rotation?
Either one or both could be; there is no way to tell from the description you give. You would have to attach accelerometers and gyroscopes to each ring to see.
Note that "assume an empty universe" means "assume Minkowski spacetime", which means you are still assuming a spacetime geometry. So the general rule I gave--that the spacetime geometry determines which states of motion will show local acceleration and/or rotation using the acceleometers and gyroscopes, and which will not--is still true. It's just that your specification of the problem does not give enough information to know how each of the rings is situated in that spacetime geometry.
Buckethead said:if you have two galaxies spinning relative to each other and they are a great distance apart and no other galaxies exist anywhere, can you say which one is spinning
Basically the same answer as above: the only difference is that you can't assume "an empty universe" in this case because the galaxies certainly have non-negligible stress-energy (whereas we could assume the rings above were idealized rings with negligible stress-energy). But there is still some spacetime geometry present, so the general rule I gave still applies. Again, the issue is that you haven't given enough information to know exactly how each galaxy relates to the spacetime geometry.
