Is There a Quicker Way to Find All Possible Values of h for fh(a+bx+cx2+dx3)?
  • Thread starter says
In summary, Row reduce the matrix to (R1+R2) to simplify and find all possible values of h. In this case, h could equal 0 or 1 depending on the values of a,b,c,d.
  • #36
So I can take this matrix:
##\begin{pmatrix} 1+1+1+h \\ 0+1+1+0 \\ 0-1-1-h\\ 0+h+0+0\end{pmatrix}##.
Row reduce it (R1+R3):
##\begin{pmatrix} 1+0+0+0 \\ 0+1+1+0 \\ 0-1-1-h\\ 0+h+0+0\end{pmatrix}## = 0
From this row reduced matrix I can see h can equal -2 and 0. So now I put both values of h (0 and -2) back into the first matrix separately and find the kernel and image for both?
  • #37
From the original matrix I can see h could also equal -3 (from the first row) of the matrix 1+1+1+h = 0
  • #38
You cannot add the columns like this.
-2 and 0 are possible values for h, but all other real numbers are possible as well.
  • #39
Ax=0
I forgot to add
x = ##\begin{pmatrix} a \\ b \\ c \\ d\end{pmatrix}##
So now I can represent them as four equations. And in those equations I can see by row reduction, and also looking at the original non-row reduced matrix, that h= -2,0,-3.
  • #40
Can you show step by step how you get that result? It is not right, and I don't understand how you get it.
  • #41
Ax = 0
##\begin{pmatrix} 1+1+1+h \\ 0+1+1+0 \\ 0-1-1-h\\ 0+h+0+0\end{pmatrix}## ##\begin{pmatrix} a \\ b \\ c \\ d\end{pmatrix}## = 0
We can row reduce this matrix, and in doing so can see h=-2,0,-3.
  • #42
Again, the addition in the matrix does not make sense.
  • #43
formatting issue, I don't mean to have the + or minus in the matrix. But we can represent the matrix as 4 equations to find h:
1a+1b+1c+hd = 0
0+1b+1c+0 = 0
0-1b-1c-hd = 0
0+hb+0+0=0
  • #44
says said:
Ax = 0
So you meant to write:
##\displaystyle \begin{pmatrix} 1&1&1&h \\ 0&1&1&0 \\ 0&-1&-1&-h\\ 0&h&0&0\end{pmatrix}\begin{pmatrix} a \\ b \\ c \\ d\end{pmatrix}=\begin{pmatrix} 0 \\ 0 \\ 0 \\ 0\end{pmatrix} \ ##​
  • #45
Yes, that's what I meant to write.
  • #46
1a+1b+1c+hd = 0
0+1b+1c+0 = 0
0-1b-1c-hd = 0
0+hb+0+0=0
Okay, now reduce this step by step to find the kernel for all real values of h. As an example, what is the kernel for h=10?
  • #47
1a+1b+1c+hd=0
0+1b+1c+0=0
0+0+0-hd=0
0+hb+0+0=0
1)R3+R2
2)R1-R2
3)R1+R3
1a+0+0+hd=0
0+1b+1c+0=0
0+0+0+0=0
0+hb+0+0=0
ker(fh) = span {(1a,0,0,hd), (0,1b,1c,0), (0,hb,0,0)}
  • #48
1a+1b+1c+10d=0
0+1b+1c+0=0
0+0+0-10d=0
0+10b+0+0=0
1)R1+R3
1)R1-R2
1a+0+0+0=0
0+1b+1c+0=0
0+0+0+10d=0
0+10b+0+0=0
ker(fh) = span {(1a,0,0,0), (0,1b,1c,0), (0,0,0,10d), (0,10b,0,0}[/QUOTE]
  • #49
You reduction algorithm appears broken.
If you subtract a multiple of a column from other columns, you must subtract the same multiple from each. You appear to have subtracted the first column as is from the middle two columns, but subtracted h times it from the fourth.
  • #50
a, b, c and d are not specific values. They cannot appear in the answer.
The kernel is the set of vectors (polynomials) [a b c d] that is mapped to the zero 2x2 matrix by fh.
  • #51
so ker(fh) = span {(1,0,0,h), (0,1,1,0), (0,h,0,0)}
  • #52
As we have ##f_h(a,b,c,d)=(a+b+c+hd,b+c,-b-c-hd,hb)## (writing everything as vectors), we get:
##f_h(1,0,0,h)=(1+h²,0,-h²,0)\neq (0,0,0,0)##
##f_h(0,1,1,0)=(2,2,-2,h)\neq (0,0,0,0)##
##f_h(0,h,0,0)=(h,h,-h,h²)\neq (0,0,0,0)## unless ##h=0##
So that seems wrong for ##Ker(f_h)##.
Hint:
  • #53
says said:
1a+0+0+0=0
0+1b+1c+0=0
0+0+0+10d=0
0+10b+0+0=0
You are not fully done with simplifications here.
Is the kernel really given by that? That's a 4-dimensional subspace, which means it is the whole space. Is everything mapped to zero?
  • #54
1a+0+0+0=0
0+0+1c+0=0
0+0+0+1d=0
0+1b+0+0=0
R4/10
R2-R4
R3/10
I'm confused by the second question.
  • #55
Just simplify your equation system one step further, what can you say about a,b,c,d? Which set of vectors satisfies all those conditions at the same time?
  • #56
1+0+0+0=0
0+0+1+0=0
0+0+0+1=0
0+1+0+0=0
a=b=c=d=0
  • #57
says said:
1+0+0+0=0
0+0+1+0=0
0+0+0+1=0
0+1+0+0=0
a=b=c=d=0
Yes, at least for most values of h.
Is there any value of h which gives a less restrictive answer?
  • #58
I don't understand what you mean sorry
  • #59
One result from your matrix equation is
hb = 0​
Doesn't this say that b = 0, unless h = 0? So, what if h is 0 ?
  • #60
if h = 0 then b could be any real number
  • #61
Right.
What's the kernel for f0 ?
  • #62
What is f0?
  • #63
says said:
What is f0?
It's fh when h = 0 .
  • #64
ker fh = span {(1,0,0,0), (0,1,1,0)}
  • #65
Let's doublecheck:
##f_0(a,b,c,d)=(a+b+c,b+c,-b-c,0)##
##f_0(1,0,0,0)=(1,0,0,0)\neq (0,0,0,0)##
##f_0(0,1,1,0)=(2,2,-2,0)\neq (0,0,0,0)##
Likes SammyS
  • #66
ker fh = span {(0,1,-1,0)}
when h=0
  • #67
when h=0
There is another vector (independent of this) in the kernel of f0 .
  • #68
but there is only one independent variable though. I thought that would mean only one vector? Unless the other vector is just (0,-1,1,0)
  • #69
How about you go back to the matrix equation you had in post #41, substitute h=0, and solve?
  • #70
ker(fh) = span {(0,-1,1,0) , (0,1,-1,0) , (1,1,1,0)}
