B Is there a specific unit used to measure redshift?
Redshift, commonly denoted as 'z', is a dimensionless quantity used in cosmology to measure the change in wavelength of light from distant objects. It is calculated by comparing the observed wavelength to the emitted wavelength, resulting in a ratio that does not require specific units. For example, if a source emits light at 500 nm and is observed at 1,000 nm, the redshift is calculated as z = 2. While the concept of a specific unit for redshift might seem beneficial, it is inherently unit-less due to its ratio nature. Understanding redshift is crucial for studying the universe's expansion and the distance of galaxies, especially with upcoming astronomical projects like the James Webb Telescope.
ASmartDude
i have been learning about using redshift to measure the distance of far-flung objects, but in all my research i never saw a specific unit used to quantify how redshifted an object is. to me it seems like an oversight, because such a unit would be very useful for the study of distant galaxies, and which the impending launch of the james webb telescope and the E-ELT project underway (i think), it seems to me such a unit would be needed for these tools to be properly used. so has anybody bothered to quantify redshift, or am i the first person to think of this?
Space news on Phys.org
Redshift in cosmology is usually labeled as 'z'. It is unit-less because you divide the units out when you compare the observed wavelength to the known source wavelength. So if we observe a wavelength of 1,000 nm from a source that we know must have emitted 500 nm light, then ##z=\frac{1000 nm}{500 nm}=2##.
Redshift is based on a ratio between wavelengths. As such it is dimensionless and does not need a unit.
The definition is ##1 + z = \lambda_o/\lambda_e##. For your example, the redshift would be ##z = 1## and ##z = 0## corresponds to no redshift at all.
that makes sense. i thought i was onto a big discovery, but i guess not. thanks for the help!
The distance, by the way, is calculated based upon a model of how the universe has expanded over time. There are some online calculators that will do this, such as this one:
http://www.astro.ucla.edu/~wright/CosmoCalc.html
It's unfortunately complicated, because distances are pretty complicated in an expanding universe.
Ah, my mistake. Thanks, Oro.
Abstract The Event Horizon Telescope (EHT) has significantly advanced our ability to study black holes, achieving unprecedented spatial resolution and revealing horizon-scale structures. Notably, these observations feature a distinctive dark shadow—primarily arising from faint jet emissions—surrounded by a bright photon ring. Anticipated upgrades of the EHT promise substantial improvements in dynamic range, enabling deeper exploration of low-background regions, particularly the inner shadow...
what is the current status of the field for quantum cosmology, are there any observations that support any theory of quantum cosmology? is it just cosmology during the Planck era or does it extend past the Planck era. what are the leading candidates into research into quantum cosmology and which physics departments research it? how much respect does loop quantum cosmology has compared to string cosmology with actual cosmologists?
