Is there an error in this paper? (modulus of elasticity vs. movement)
In summary, this paper discusses the different types of retaining screws and their advantages and disadvantages. Titanium is a stronger material, but may cause galling. Gold screws are more flexible, but may loosen.
swampwiz
571
83
NOTE: I seem to have a dental implant in which there has been a mechanical failure of the abutment, which has piqued my interest in this.
The paper is here: https://www.ncbi.nlm.nih.gov/pmc/articles/PMC4668729/
About 40% down, there is:
The most commonly used retaining screws are either of gold or titanium. Gold screws are designed to be the most “flexible” portion of the implant assembly. Due to their higher modulus of elasticity than titanium, they permit an adequate micro movement to distribute force to the implant body.[37] Implant posts, that are retained with gold or gold coated screws, show a reduction of screw loosening and improved clamping force in comparison with titanium screws.[38,39,40]
Titanium alloy has four times the bending fracture resistance of grade 1 titanium. Therefore, abutment screws made of grade 1 titanium will deform and fracture more easily than the alloy. A higher torque magnitude can be used on the titanium alloy abutment screw and female component (implant body).[36] Titanium retaining screws are stronger than gold, but have a lower modulus of elasticity; metal fatigue will produce a gold screw fracture before the titanium retaining screw is affected.[37] The major disadvantage of titanium retaining screws is their tendency to cause galling, which results in excessive friction between the two mating surfaces there by causinga localized welding with a further roughening of the mating surfaces.[41] Galling occurs in the following manner: Titanium of the retainings crew slides in contact with the titanium of the implant body, the coefficient of friction increases whereby titanium molecules transfer from the mating surfaces.[42] This has been described as the adhesive wear mechanism[43] which causes slight damage to both the implant body and the retaining screw threads.
This seems to make no sense. It would seem that a material with a higher modulus of elasticity would be less flexible and harder to have "micro movements". Also, looking up this property for the elements @ Wikipedia, gold is at 79 while titanium is at 116 (GPa), which seems to be completely contradictory to what is presented in the paper.
You are correct, higher modulus = lower strain per unit stress i.e. stiffer material. It appears the author has "inadvertently" used the term modulus of elasticity when flexibility was what he intended. It may have been, since he is writing "a review of current technology" he may have not technically understood what "modulus of elasticity" represented and assumed a higher modulus indicated more flexibility. If you clip on "more author information" you will see that all of the authors are from "Babu Banarasi Das College of Dental Sciences" so engineering terminology may not be their strong suit.
Related to Is there an error in this paper? (modulus of elasticity vs. movement)
1. What is the significance of the error in the paper?
The error in the paper is significant because it affects the accuracy and validity of the results presented. Modulus of elasticity and movement are important factors in many scientific studies, and an error in their measurement can lead to incorrect conclusions.
2. How was the error detected?
The error was detected through careful analysis and comparison of the data in the paper with known values and previous studies. It is important for scientists to constantly review and verify their findings to ensure accuracy.
3. Can the error be corrected?
It depends on the nature and extent of the error. If it is a minor error, it may be possible to correct it through reanalysis or recalibration of the data. However, if the error is significant and cannot be corrected, it may be necessary to retract the paper and conduct further research.
4. What impact does the error have on the conclusions of the paper?
The error may have a significant impact on the conclusions of the paper, as it can change the interpretation of the results and the overall findings. It is important to address and acknowledge the error in the paper to ensure the accuracy of the conclusions.
5. How can future errors be prevented in scientific papers?
To prevent errors in scientific papers, it is important for researchers to follow rigorous and standardized methods of data collection and analysis. Additionally, peer review and open communication within the scientific community can help to identify and correct errors before they are published.
  • Materials and Chemical Engineering
9K
  • Mechanics
27K
  • Computing and Technology
  • Other Physics Topics
