dubey suraj
- 2
is there any derivation of Newton second law?
dubey suraj said:is there any derivation of Newton second law?
I totally agree. Newton's 2nd law is an empirical relationship that Newton formulated based on his laboratory experiments. The mass m was the proportionality constant between force and acceleration.Orodruin said:No. Physics is an experimental science and as with all physical laws, it is postulated and then evaluated based on how well it predicts what we can observe. Newton's second law is very (very) good at predicting observations.
dx said:Today, we take conservation laws as fundamental, so Newton's second law is a consequence of the conservation laws. For a particle,
[tex] E = P^2/2m + V(X) [/tex]
So dE/dt = 0 implies
[tex] \frac{P}{m} \frac{dP}{dt} + \frac{dX}{dt} \frac{dV}{dX} = 0 [/tex]
Or
[tex] \frac{dP}{dt} = F [/tex]
More generally,
[tex] \frac{d}{dt} E(X, P) = \frac{\partial E}{\partial X} \frac{dX}{dt} + \frac{\partial E}{\partial P} \frac{dP}{dt} = 0[/tex]
With some more thought which I won't go into, you can get Hamilton's equations:
[tex] \frac{dP}{dt} = - \frac{\partial E}{\partial X} [/tex]
[tex] \frac{dX}{dt} = \frac{\partial E}{\partial P} [/tex]
The relativistic generalization of dE/dt = 0 is
[tex] \partial_\mu T^{\mu \nu} = 0 [/tex]
which are the equations of mechanics in their most complete form, much more comprehensive than F = ma.
I am not going to argue against this, my point is that from what I read out of the OP, I do not think that he/she is at the level where such an appreciation can be reached. The next question is going to be "can you derive the conservation of the quantity X?" I think this needs to be done on a much more fundamental level regarding how experimental sciences are done.dx said:The OP can ignore the relativity and Hamiltonian part, but I think it is helpful for students to appreciate the logical structure of mechanics that the conservation laws (or equivalently, the symmetries) are the fundamental things. There is nothing more to mechanics than conservation laws.
Philip Wood said:(1) Re posts 5 and 7, the difficulty of regarding N2L as empirical is how you measure force, though I have to admit that the high school approach of accelerating a trolley using identically extended identical springs in parallel (one by itself, them 2 in parallel, then 3 in parallel) would satisfy me as the basis of showing that rate of change of momentum is proportional to force. This relies on two 'common notions' about force: that equally stretched springs exert equal forces, and that forces pulling in the same direction add together like scalars. No doubt a purist wouldn't grant these, and would have to regard N2L as a definition of force in terms of acceleration or in terms of rate of change of momentum.<snip>.
H Smith 94 said:F(t)=v(t)dm(t)dt+m(t)a(t),F=vdm/dt+ma.
This is Newton's second law in its most general and explicit form.
Andy Resnick said:No- Newton's second law is a definition.
bhobba said:I thought Noethers Theorem was the explanation for conservation laws - in fact momentum and energy are in modern treatments defined using it eg momentum is the conserved Noether charge related to spatial translational symmetry. The reason Noether can be applied is the Principle of Least Action is true. That would seem the fundamental principle.
Thanks
Bill
Philip Wood said:But if the mass accreted is moving with velocity w before accretion, then the force equation becomes…
F= (v – w) dm/dt + ma.
Philip Wood said:Then momentum of system at time [itex]t + \Delta t[/itex] = momentum of system at time t + F[itex]\Delta t[/itex]
Philip Wood said:So
[tex](m + \Delta m) (\mathbf{v} + \Delta \mathbf{v}) \ = m \mathbf{v} + \Delta m \mathbf{w} + \mathbf{F} \Delta t[/tex]
Philip Wood said:Leaving out, for the time being, the F delta t term in my handwritten derivation, I'm simply applying the principle of conservation of momentum to the system consisting of delta m and m.
Could you please tell me if you're happy with that?
But Delta m sticks to m, so both m and (m + Delta m) have the same final velocity, namely (v + Delta v). So Delta v is the change in velocity of m.DrStupid said:- Δv is not the change of velocity of m, but the difference between the the initial velocity of m and the final velocity of the total system consisting of m and Δm
What I'm taking as the total system is the accreting body and the stuff it accretes in time Delta t. So the mass of the total system is constant. dm/dt is indeed the rate of change of mass of the accreting body. That's what I intend it to be. Likewise, I'm intending a to be the acceleration of just the accreting body.DrStupid said:a and dm/dt are not the acceleration and the change of mass of the total system, but of the body only
Philip Wood said:But Delta m sticks to m, so both m and (m + Delta m) have the same final velocity, namely (v + Delta v). So Delta v is the change in velocity of m.
Philip Wood said:What I'm taking as the total system is the accreting body and the stuff it accretes in time Delta t. So the mass of the total system is constant. dm/dt is indeed the rate of change of mass of the accreting body. That's what I intend it to be. Likewise, I'm intending a to be the acceleration of just the accreting body.
Philip Wood said:Good. Hope that my treatment of a non-zero F (from outside the system) acting on the accreting body is also acceptable. I argue that in time delta t it delivers momentum F delta t.
As I said above, my system is the accreting body and the stuff it accretes in time delta t. So mass delta m isn't transferred into the system, but is transferred within the system. The overall mass of the system remains constant at (m + delta m).DrStupid said:considering the transfer of Δm into the system
In the last but one 'side' of your equation, it's not just mv that you should be subtracting but also the initial momentum of Delta m, which (see post 15) is (Delta m)w. That way we get the change in momentum of the system.DrStupid said:Δp=p(t+Δt)−p(t)=(m+Δm)⋅(v+Δv)−m⋅v=F⋅Δt
Philip Wood said:As I said above, my system is the accreting body and the stuff it accretes in time delta t. So mass delta m isn't transferred into the system, but is transferred within the system. The overall mass of the system remains constant at (m + delta m).
Philip Wood said:If we put F = 0 into your equation as quoted then we find that delta v is independent of w.
Philip Wood said:This can't be right, as, with F = 0, we are dealing with a simple case of a two body collision.
No, but I do talk about the force on a BODY of varying mass. My point is that in Galilean/Newtonian Physics a body can't acquire mass without the mass coming from somewhere outside the original body. And as the body acquires mass it also acquires momentum, dependent on the velocity of the acquired mass before it was acquired. You haven't (yet) convinced me that the equation I gave originally is wrong.DrStupid said:Than we do not talk about the force acting on a system with variable mass.
Philip Wood said:No, but I do talk about the force on a BODY of varying mass.
Philip Wood said:My point is that in Galilean/Newtonian Physics a body can't acquire mass without the mass coming from somewhere outside the original body. And as the body acquires mass it also acquires momentum, dependent on the velocity of the acquired mass before it was acquired.
Philip Wood said:You haven't (yet) convinced me that the equation I gave originally is wrong.
I agree with your summary (A, B, C, D, a, b). I agree, too, that the force FAD is not related to any kind of mass transfer, in that I'm trying to deal with cases where the force and the mass-accretion are independent, in the sense that we could conceive of either being turned off independently of the other e.g mass-accreting body experiencing a force (say from an electric field) unrelated to the mass accretion.DrStupid said:I counted four systems
A: the body of initial mass m
B: the additional mass Δm
C: the common system of the body and the additional mass
D: an external system exerting a force the body
and two interactions
a: the collision of A and B
b: the force F between A and D
Is this correct?
If yes, than force F is not related to any kind of mass transfer. In that case your scenario is not suitable for the discussion of forces between open systems.
But my force wasn't the force of B on A, but was a force from outside (D in your notation).DrStupid said:I repeat my calculation from #24 with your force. The forces between the interacting open systems are
FA=mA⋅v˙A+(vA−vB)⋅m˙A
