- #71
Averagesupernova
- 1,287
edward said:I am aware of how it is mixed. It is mixed in ounces per gallon of water.
Apparently you are not. It's use is spec'd in ounces per acre. 20 to 30 oz is common. The amount of water used is not so specific. 8 to 15 gallons per acre of water is common. It will depend slightly on the type and size of sprayer. The nozzles used will somewhat govern how much water per acre is used. Small nozzles require less gallons per acre since to drive the machine at a reasonable speed the pressure has to be increased in order to get the amount required out the nozzle. This higher pressure can lead to a lot of fog coming off of the machine which causes higher probability of it drifting to where it does not belong. Naturally spraying less gallons of water is desirable since more ground is covered between fills.
But, it can get to the point of having to drive too fast with larger nozzles. For the nozzle to work correctly the pressure has to maintain a minimum and in order to get the proper amount out the nozzle the pressure has to be dropped on a large nozzle otherwise too much will be sprayed.
No matter what amount of water is chosen, naturally in order to maintain the proper rate of active chemical the same amount must be sprayed out throughout the entire tank.
There are also machines that use chemical injection. This method directly injects the pure active chemical (Roundup for this discussion) into the plumbing using a metering pump.
Roundup is also labeled for a maximum amount per acre per year. This is a pretty high amount compared to what is typically sprayed.
Whatever you claim to have seen may seem sloppy but I doubt it was. I think there is more to it than what you saw.
