Is there some type of Thermal Ceiling?
  • Thread starter Thread starter Plasma
    Thermal Type
Temperature cannot exceed certain limits, such as the maximum temperature achievable by focusing sunlight, which is constrained by the sun's own temperature. Theoretical discussions suggest that an upper limit might exist when molecular kinetic energy approaches the speed of light. However, kinetic energy can increase indefinitely, merely approaching but never reaching these limits. Excessive energy concentration could lead to extreme phenomena, such as the formation of black holes. Overall, while absolute zero is a defined lower limit, the upper limits of temperature remain speculative and complex.
Plasma
Temperature can't get lower than absolute zero, so is there some point in which it can't get higher?
Science news on Phys.org
In some situations there is, for example you cannot focus sunlight to heat something above the temperature of the sun.
I suppose one upper limit of temperature would be when molecules have enough kinetic energy to be moving at near c. Of course, there's still the issue of how dense the distribution of those atoms are. And then you could always add IR EM.
Kinetic energy can be large without bound, all it does is add more nines i.e. .99999c instead of .999c.
As an upper limit, too much concentrated energy will rip a (black) hole in the universe. It would be quite a spectacle to watch a motor with 10^60 horsepower rip itself into a black hole.
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
