Is This a New Expression for the Beta Function?
A new expression for the Beta Function has been proposed, defined as B(x,y) = (Γ(x)/x) * (∑(k=1 to y) (Γ(x+y-k)/Γ(y-k+1)))⁻¹, applicable for non-negative integer pairs of x and y. The formula bears resemblance to the traditional Beta Function representation, B(x,y) = (x-1)!(y-1)!/(x+y-1)!. The discussion confirms that y is indeed the upper bound of the summation in the new expression. The community is invited to verify if this expression is previously known or truly novel. The exploration of this potential new formulation of the Beta Function is deemed interesting.
PhysicsRock
So, I've recently played around a little with the Gamma Function and eventually managed to find an expression for the Beta Function I have not yet seen. So I'm asking you guys, if you've ever seen this expression somewhere or if this is a new thing. Would be cool if it was, so here's the formula:
B(x,y) = \frac{\Gamma(x)}{x} \cdot \left( \sum_{k=1}^{y} \frac{\Gamma(x+y-k)}{\Gamma(y-k+1)} \right)^{-1}
Obviously, this only works for non-negative integer pairs of ##x## and ##y##. Still pretty interesting I think.
Mathematics news on Phys.org
Sure you have ##y## as upper bound of the sum?
Anyway, it looks very similar to ##B(x,y)=\dfrac{(x-1)!(y-1)!}{(x+y-1)!}##
Yes, ##y## is definitely the upper bound.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
