Is This an Example of Absolute Value Inequalities?
  • MHB
  • Thread starter mathdad
In summary, the conversation discusses solving an absolute value inequality and using a theorem to determine the solutions. The conversation concludes by stating that the solution can be easily found.
mathdad
1,283
Solve the inequality.
| (4 - 5x)/2 | > 1
Can I use the following theorem?
If a > 0, then | u | > a if and only if u < -a or u > a
Mathematics news on Phys.org
Yes, you can: either \(\displaystyle \frac{4- 5x}{2}> 1\) or \(\displaystyle \frac{4- 5x}{2}< -1\). Continue, with either equation, by multiplying both sides by the positive number, 2.
I can take it from here.
| (4 - 5x)/2 | > 1
We are given:
\(\displaystyle \left|\frac{4-5x}{2}\right|>1\)
Multiply through by 2/5:
\(\displaystyle \left|x-\frac{4}{5}\right|>\frac{2}{5}\)
Now the solution is easy to read off...:D
Is the question what is known as absolute value inequalities?
FAQ: Is This an Example of Absolute Value Inequalities?
What is an inequality?
An inequality is a mathematical statement that compares two quantities and uses symbols such as <, >, ≤, or ≥ to show which quantity is larger or smaller. Unlike equations which have an equal sign, inequalities have a range of possible solutions.
How do I solve an inequality?
To solve an inequality, you must isolate the variable on one side of the inequality sign. This can be done by using inverse operations, just like solving an equation. Remember to reverse the direction of the inequality sign if you multiply or divide by a negative number.
What are the different types of inequalities?
The three main types of inequalities are linear inequalities, quadratic inequalities, and rational inequalities. Linear inequalities involve a linear expression on one side of the inequality sign. Quadratic inequalities involve a quadratic expression on one side. Rational inequalities involve a rational expression on one side.
What is the difference between an open and closed circle on a number line?
An open circle on a number line represents a number that is not included in the solution of the inequality. A closed circle represents a number that is included in the solution. This is important to note when graphing solutions on a number line.
Can you solve inequalities with more than one variable?
Yes, inequalities with multiple variables can be solved by isolating one variable on one side of the inequality sign and then using substitution to solve for the remaining variables. It is important to keep track of the inequality sign and any restrictions on the variables. Graphing the solution in the coordinate plane can also help visualize the solution.
