Is this how I would determine the force?
  • Thread starter Thread starter HELP_786
    Force
To determine the force constant (k) of the metal plate, the user needs to apply the formula T = 2π√(m/k), where T is the period of vibration and m is the mass attached. By rearranging the formula, k can be calculated once the period (T) for each mass is known. The discussion emphasizes the importance of using the average time for 10 vibrations to accurately derive T for each mass. The user confirms they have the period values necessary for this calculation. This approach effectively allows for the calibration of the force constant of the metal plate.
HELP_786
Is this how I would determine the force??
A thin, flexible metal plate attached at one end to a platform, as shown above, can be used to
measure mass. When the free end of the plate is pulled down and released, it vibrates in simple harmonic motion with a period that depends on the mass attached to the plate. To calibrate the force constant, objects of known mass are attached to the plate and the plate is vibrated, obtaining the data shown below.
mass (kg)
avg time for 10 vibrations (seconds)​
.10
8.86​
.20
10.6​
.30
13.5​
.40
14.7​
.50
17.7​
now my question is, if i was to find the force constant of the metal plate, would that mean that i need to find k?
if so, would i do that by using the formula T=2π√m/k)?
oh yea, and i also have the value of for T(period) for each of the masses
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
