Is this the answer for what is the residue of f(z)=e^z/[(z-1)^2(z+2)]
  • Thread starter Thread starter laura_a
    Residue
laura_a
This was an exam question I had today:
Give the location and order of each pole of
and evaluate the reside at these points
Res(f(z)) = g(p-1)(a) / (p-1)!
g(z) = e^z/(z+2)
g'(z) = -e^z/(z+2)^2
let a=1
g'(1) = -e^1/9
So res(f,1) = -e/9
Then I did
g(z) = e^z/(z-1)^2
(this is the part I think I might have stuffed up, because I did use the formula above but I had m=1 for f(z) which was 1/(z+2) so I thought it was right? anyways I got
g(-2) = e^(-2) / (-3)^2 = res(f,-2)=1/(9e^2)
It would mean a lot to me if someone could let me know because I am trying to work out if I should be depressed because I failed or if I can be happy because I passed :)
At first glance I agree with your first answer for res(f,-2) but not for res(f,1).
<br /> g\left( z \right) = \frac{{e^z }}{{\left( {z + 2} \right)}} \Rightarrow g&#039;\left( z \right) = \frac{{e^z }}{{\left( {z + 2} \right)}} - \frac{{e^z }}{{\left( {z + 2} \right)^2 }}<br />
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
