Is time a true variable in the scheme of things?
In summary: Earth. However, each clock has experienced one second per second. The clock on Earth has experienced 60 seconds and the other clock has experienced something like 60.000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001 seconds. In summary, the conversation discusses the concept of time passing at different rates depending on various factors such as motion and gravity. While it is possible to slow down time, there is no known way to significantly speed it up without causing any physical differences. The idea of changing the speed of time for a clock is also explored, with the conclusion that it is
Suppaman
128
TL;DR Summary
We can affect the passage of time by motion or gravity, does this make it just a parameter affected by "things" in the universe? We can make it go faster?
I accept that time can pass at different rates depending on if the applied motion or gravity (both a parameter in some formula) and as a result time passes at a different rate. However, this seems to imply that we have some control over how slow time may pass. So, if that is just a fact of the physical universe, please let us develop a means of speeding up time. The math problems that would take the age of the universe to calculate could be done in a blink of the eye if the appropriate values of attributes were applied to whatever controls the passage of time for an object such as a computer. Since slowing time down does not seem to violate any of the fundamental laws of the universe perhaps speeding time up will work? I did some searching on the web and did not find anything about this.
Likes Delta2
If you did speed up time, I'm not sure how anyone would notice.
A clock would record more time.
More than what?
If time sped up. Let's say a year passed in a day, whatever that might mean. Then the Earth would orbit the Sun, we'd all physically be a year older, the clocks would have advanced a year and no one would have noticed any difference from a normal year. Everyone would think a year had passed. And, in a way, it would have. Who would know that only a day had passed?
If a year's worth of physical change has taken place, then isn't that by definition a year?
When we measure time passing by clocks at a different distance from a gravitational source we notice the difference. If we had a way to change the speed of time for a clock it could record more time than a reference clock.
@Suppaman, it's not quite clear but I think you may have a fundamental misunderstanding. No matter where you are in a gravity well, or how fast you are going relative to some frame of reference, your time does NOT go faster or slower. It just chugs along at one second per second. I think you are confusing differential aging with time dilation.
Likes davenn and Greg Bernhardt
You just tinker with the mechanism. Then it would run fast. But, that wouldn't be any physical difference. If you want to change all clocks, then everything is a clock. Your body chemistry and biology included. So, if "local time" changed you wouldn't notice it, because you would be changing too.
In terms of gravitational time dilation, that is time somewhere else. If you travel on a relativistic space flight and/or hover close to a black hole then return to Earth, then a long time may have passed on Earth. But, the people on Earth didn't think that their lives passed in a second. They would have lived and experienced normal lives.
The clock ten feet higher than where I am is experiencing a different rate of time then I am. A clock on a satellite moving at a faster speed than I am is experiencing a different clock time than I do. If I had a means of affecting whatever controls the rate of time in an object it would be useful. Motion and gravity can do it, perhaps there is a way of speeding time up. Is that against any of the laws of physics? We can slow it down, why not speed it up?
Likes Delta2
Absolutely not correct. You are, as I assumed, confusing differential aging with time dilation. EVERY clock everywhere, at whatever speed, "experiences" exactly the same rate of time. What is confusing you is that clocks can (a) APPEAR different to a non-local observer and (2) take different paths through space-time so that if two of them are synchronized and then moved apart and then back together they can have experienced a different number of ticks (but again, each at one second per second).
Those differences are so small that they are of no practical value. It's possible of course, if you wanted to preserve something, you could send it off on a relativistic space flight. But, that's not very practical.
There's no way to speed something up significantly relative to us on Earth, for example. That would be really useful. A computer could run a long program in no time. But, there's no way to do that.
If you put it into space, then technically it's runner faster than an equivalent computer on Earth, but the maximum you can gain from this is very small. The Earth's gravity is too weak.
No, it is not. You are making the same mistake as the OP. It is running at one second per second. It LOOKS like it is running faster and if you bring it back to Earth it will have ticked a different number of times, but it will not have done so at a different rate, it will simply have taken a different path through space-time.
Likes davenn
In practical terms it's running faster.
No, it's not. In practical terms, you have to account for the fact that is moving through space-time on a different path than an Earth-bound clock, but saying that it is running faster is just wrong.
Likes davenn
If we lived in a universe where gravitational time dilation was significant, then things like computer rooms would be built as high as possible. And, for all practical purposes, they would run faster than computers in the basement.
Okay you could quibble that its time that is running faster, not the computer; and then you could quibble that time is inherently running at the same rate in the attic and the basement, it's just different relative to each other. But, in the end, if one program finishes long before another then it must have run faster - relative to the end user if nothing else!
Likes russ_watters
Careful here... you are making an assumption that is so natural that you probably are not aware of making an assumption, but that cannot be justified. We have two clocks at different heights and we claim that time is passing more slowly for the lower clock. What exactly are we saying here?
At the same time that the lower clock reads ##T##, the upper clock reads ##T'##.
Later the lower clock reads ##T+\Delta{T}## and at the same time the upper clock reads ##T'+\Delta{T}'##.
##\Delta{T}'\gt\Delta{T}## so we say that time is passing more slowly for the lower clock.
But look at what we're saying more closely. The claim depends on how we determine ##\delta{T}## and ##\delta{T}'##, and that in turn depends on the vital and dangerously slippery phrase "at the same time". What exactly does it mean to say that two things are happening "at the same time" at two different points in space?
You are making the assumption that "happens at the same time" is an absolute property of a pair of events, and when you look more closely at that assumption (by trying to answer the "How exactly?" question above) you will find it harder to justify than you expect. In fact, it cannot be justified at all - it is simply false, as shown by Einstein's classic train thought experiment on the relativity of simultaneity.
Not really, the clock keeping time for both are identical and keep time very well. Move one up the hill and it no longer keeps the same time as the lower clock. An often repeated experiment. I do not have to compare events in the clock as to when they happen. The difference is how fast the clock runs.
Persisting in this incorrect point of view will never make it correct.
Also, it will prevent you from understanding the physics of what is actually happening.
Is there a question about the two clocks giving different time depending on their same position on the Earth surface but at a different height?
My original question concerned making a clock go faster, not slower.
Re-read post #15
I just did, I was not talking about things happening at the same time. Only that the clocks at different heights recorded different elapsed time. No comparison was intended to relate events between the two clocks.
Actually, I can give you a better answer. We on Earth are are almost following a natural path through spacetime. The defining property of a "natural path" or "geodescic" is that it maximises the time you experience. There is a more precise definition of what this means, but that should do for now. No other path than recrosses the a geodesic can have a greater elapsed or "proper" time than along a geodesic.
1) If you could move something to a higher gravitational potential, then it would age faster relative to you. But, as we are at a high potential already there is not much to be done.
2) As we are close to a geodesic path then generally any deviation will result in ageing slower. The options for experiencing less time are much more limited. The best you could do is perhaps move to the north pole, where you are essentially in free fall around the Sun. Again, the differential ageing for someone at the pole is negligibly less than for someone at the equator.
The short answer is, therefore, that there is no path through spacetime where you would return to Earth significantly older than someone who stays on Earth. But, there are paths where you would return significantly younger than those who stayed on Earth.
A reference clock where? What would this get us?
I suppose if you want a reference clock to record more time than a second clock you could send the second clock on a high-speed trip to the nearest black hole and back. I'm not sure why we'd want to do that though.
Sure, you just reverse which clock you call the "reference".
Let me give an example. Say we had a means of generating some "field" that caused something within that field to experience a different rate of elapsed time. To be able to do in the lab what currently requires a trip in space at a high speed or in a stronger gravitational field. We can not do this but the concept is valid as we know time can be manipulated. This is accepted.
Now, my question is there any way to speed up time for an object? What would that do for us? Well if you could control this locally it would make for faster computers. If a computer had to run for a week now to get a result if the computer was in a room where time was accellerated it might do a weeks calculation in a second rather than a week. The concept of a slower clock for our near light speed trip is accepted.
Is there any physics rule that would prohibit us from finding a way to speed up time? If time can be slowed, why not made faster?
See post #21.
I just did and there was no mention of anything that prohibited it. You talked about a path through spacetime, that is not my question area.
It's not prohibited. But, there is limited scope. All the differential ageing you are referring to is related to your path through spacetime. The path we are following here on the surface of the Earth is so close to a natural path that our proper time is almost maximised. There is limited scope to take a more natural path. There is, however, no limit in going the other way and taking a path that significantly minimises ageing compared to life on Earth.
The short answer is that there is no way to have significant positive ageing compared to life on Earth. But, you can have significant negative ageing. The key factor is the scope and scale available.
These experiments have been done, but they don't mean what you think they do.
In cases like the GPS system where the clocks are not colocated, there is always an "at the same time" assumption present and the claimed difference in the clock rates is (as in #15 above) determined by which assumption the experimenters have chosen. The assumption may be more or less hidden (inthte case of the GPS system it is explicitly stated) but it is always there.
Experiments such as Hafele-Keating, in which clocks are separated and brought back together avoid the "at the same time" problem because the clocks are colocated when we compare them, but they aren't measurig the rate at which time passes. They are measuring something completely different, namely the length of the paths through spacetime that the two clocks took. It's like comparing the odometers of two cars - you can conclude that they've driven different distances but the odometers both work at the same rate: one kilometer per tick of the odometer..
Suppaman said:
... we know time can be manipulated. This is accepted.
No, it cannot and such a concept is not "accepted". What is accepted is that it is possible to take different paths through space-time. You continue to refuse to understand the underlying physics.
You are teaching me. So, it is a different path for the two separated clocks on earth, the higher clock travels a longer path, it is not the difference in gravity felt by the clocks? Is this correct?
On a flat piece of paper draw two dots, and then connect them with a straight line. Let the length of that line segment be ##L##. Now, you can draw all kinds of kinked lines connecting those same two dots. When you measure the lengths you always get a total length that's greater than ##L##.
Does it therefore seem possible that you can connect the dots with a line whose length is less than ##L##?
Likes cyboman
  • #31
Whatever the process is that controls how time passes for an object (and there are no lines) the object is moving about and when it returns home and it compares clocks the moving objects clock has counted less time. Now, what makes it not possible to find some way to manipulate the clock and everything else in that object so it can do "something" and when done compares clocks and find that more time has passed for the object. I do not think we really know the mechanics of what makes time pass at a given rate. Must it be a gravitational field, motion through space, something else? Since we know things can experience slower time the universe allows that, does it allow faster time?
  • #32
You are right that gravitational time dilation is calculated from the gravitational potential, not the gravitational force. But look again at what I said in #27 above - the situation in which the two clocks start together, separate, then come together again later so that we can see which one has ticked off more time is completely different from the situation in which we have a higher clock and a lower clock and we say that the lower clock is running slower than the higher one. Which case are you asking about in the text I just quoted above?
  • #33
I thought that it was the difference in gravity that explained the two clocks on Earth but just separated. I can see that the higher clock does cover more distance through spacetime. But my post is not to explain what we know, it is to ask about having a situation where we can make a clock go faster and if physics prohibits that.
  • #34
Suppaman said:
Whatever the process is that controls how time passes for an object (and there are no lines)…
There is no such process because time always passes at the same rate, one second per second, just like the odometer of a car clicks over once every kilometer you drive. There’s nothing to control.
There are lines (called “worldlines” and it is essential that you learn what they are - drawing and understanding them in ordinary flat Minkowski space is a good exercise and you have to be able to do that before you can take on gravitational effects anyway so you might as well try it).
You would have to send the object on a longer path through spacetime, so that its clock would tick off more time between departure and returning home (just as we could send a car on a long detour if we wanted to cover more kilometers on a trip between points A and B) . Here the two points are the events “clocks separate” and “clocks rejoin”. However, it turns out that the longest possible path between two points in spacetime is the path followed by an object that is in free fall between them - and that’s the path followed by the clock that isn’t moving about, just sitting still waiting for the other one to come back. You
In this regard spacetime is different from ordinary three-dimensional Euclidean space, the stuff we learn about in high-school geometry class. In Euclidean space, there is a shortest distance between two points, the straight line connecting them. In spacetime the geometry is non-Euclidean and instead of a shortest distance between two points there’s a longest distance and you can’t find any longer distance.
speak for yourself now...
Likes cyboman and Andrea Panza
  • #35
Because the clock that stayed at home shows the maximum possible elapsed time. Just as the shortest distance between two dots on a flat sheet of paper is a straight line. You seem to have trouble accepting the first claim, but you haven't responded to the validity of the second statement. Every thing you wonder about the validity of the first statement can be said of validity of the second statement.
For example, why is it not possible to make the distance between the dots on the flat sheet of paper less than the length of the straight line? Is there something wrong about the way we've defined length? Whatever the process that controls the length of the line, the straight line is always the shortest.
Likes cyboman and phinds
  • Other Physics Topics
  • Astronomy and Astrophysics
10K
  • Classical Physics
