B Is time a true variable in the scheme of things?
  • B
  • Thread starter Thread starter Suppaman
    Time Variable
The discussion centers on the nature of time as a variable influenced by motion and gravity, raising the question of whether it can be manipulated to speed up its passage. Participants argue that while time can appear to pass differently for observers in varying gravitational fields or speeds, all clocks measure time at a consistent rate of one second per second. The concept of differential aging versus time dilation is debated, with some suggesting that if time can be slowed down, it should theoretically be possible to speed it up as well. However, practical applications of such manipulation seem limited, as any significant changes would not be noticeable to those experiencing them. Ultimately, the conversation highlights the complexities of time measurement and the challenges in altering its flow within the constraints of current physics.
  • #51
cyboman said:
From an astronomical viewpoint, mass effects space-time, and the bodies that interact with that gravity / forces follow arcs, not straight lines. Because the space itself, is curved.
Before Einstein it was clear that the Earth traveled in a curved (almost circular) orbit through space around the sun.
Ironically, Einstein found that, in a way, the Earth follows a straight line through curved spacetime.
Likes cyboman
  • #52
cyboman said:
A straight line through curved space time is an arc.
You ought to research the term "geodesic".
In any case, the geodesics of spacetime, which are the paths that particles and planets naturally take, are paths of maximal spacetime distance.
Likes cyboman
  • #53
So from an objective frame, does the particle follow a straight line, or does it follow a geodesic arc along space-time? What is your frame of reference?
  • #54
Geodesics are independent of frame of reference.
As I said, many people consider a geodesic as the definition of a straight line.
Personally, I reserve straight line for Euclidean geometry and simply use geodesic.
But, there is no other possible definition of a straight line in curved spacetime. It's either a geodesic or left undefined. An arc is likewise an undefined term.
One problem with the question is that descriptions like straight line and arc depend on your coordinates. Unless you give them some coordinate free description, like shortest distance between two points, or maximal spacetime distance between two points.
You can define a straight line in these ways in classical mechanics and SR. And you can extend the latter definition to curved spacetime if you wish. But unless you do that straight line has no meaning in curved spacetime.
Likes cyboman
  • #55
Fascinating.
I guess I was thinking that the conventional Newtonian idea of a straight line, in a curved space-time is actually an arc. This is what I come to understand of SR. The shortest distant turns out to be a curve, not a line, because the space itself is bent and non-euclidean due to gravity.
  • #56
cyboman said:
Fascinating.
If you take an example from Newtonian physics. A ball falls straight down under gravity. That is spatially a straight line in the Earth's reference frame. But if you plot height against time, then as the ball is accelerating it's path in Newtonian spacetime is curved.
Whereas a ball moving at constant velocity would follow a straight line through Newtonian spacetime.
This is also true in the flat spacetime of SR.
But, in GR the ball falling under gravity is not accelerating. In the sense that it feels no force and has no intrinsic or "proper" acceleration.
Whereas the ball rolling along a table does feel an upward force from the table, so is accelerating.
The situation in GR is somewhat reversed. And, it is not just semantics to say that the ball in free fall - or a planet in orbit - is following a natural, geodesic "straight" path through spacetime. And the ball rolling at constant velocity is not following a geodesic path but being accelerated in a "curved" path.
  • Love
Likes cyboman
  • #57
cyboman said:
But I would contend, the mathematics are not euclidean. Or flat.
The spacetime of special relativity is flat, but it is not Euclidean.
  • #58
cyboman said:
Note that the shortest path in space time is a curved line not a straight one.
There is no shortest path through spacetime for objects with mass. However short a path you choose, a shorter one can always be found.
Just as, on that flat sheet of paper I was talking about, there is no longest path between the two dots. However long a path you choose, a longer one can always be found.
Likes cyboman
  • #59
Thanks for the examples!
But isn't it true that that's because it locally only appears that way. Because you are in effect zoomed in so far. It looks like it's straight, but if you go far enough out it's actually happening in curved space-time. So like everything else, the ball exists in curved space-time due to the mass of the Earth.
But when you say flat spacetime, are you not assuming there is no gravity. Empty spacetime is flat where no masses are curving it.
Is a geodesic path not curved? Zoomed in locally it appears straight. It's as close to straight as you can get, but it's still a curve. So, there are no straight lines in curved space-time. Isn't that correct? If there is no Earth then the space-time is flat and you could say there are straight lines right.
  • #60
It's only flat if there is no masses curving it though right? In the context here the Earth is curving space-time.
I'm wondering, could one argue that everywhere in the universe space-time has some curvature?
  • #61
I'm lost on this one. I thought that an object moves along the shortest path between two points in space-time.
  • #62
No, as been already pointed out:
PeroK said:
In fact, in flat spacetime the straight line is the longest path between two points.
In fact, from the mathematical point of view, the path has to extremize certain functional, which means it's not always minimal, but can be maximal.
Likes cyboman
  • #63
Most usually, the longest path. That is, the longest elapsed proper time from starting event to ending event.
Likes cyboman
  • #64
I think this notion is beyond my capacity to understand. Reminds me of the time cone stuff I remember reading in A Brief History of Time. But I think I need to reread that and some of the explanations you all gave a few hundred times more to really get a handle. Fascinating stuff though!
Thanks for your explanations. Don't want to hijack the thread (hope I haven't).
Likes PeroK
  • #65
Suppaman said:
Let me give an example. Say we had a means of generating some "field" that caused something within that field to experience a different rate of elapsed time. To be able to do in the lab what currently requires a trip in space at a high speed or in a stronger gravitational field. We can not do this but the concept is valid as we know time can be manipulated. This is accepted.
Now, my question is there any way to speed up time for an object? What would that do for us? Well if you could control this locally it would make for faster computers. If a computer had to run for a week now to get a result if the computer was in a room where time was accellerated it might do a weeks calculation in a second rather than a week. The concept of a slower clock for our near light speed trip is accepted.
Is there any physics rule that would prohibit us from finding a way to speed up time? If time can be slowed, why not made faster?
I think the issue is obervational. Frame of reference is what gives rise to the differentiation between two time measuring devices. A discreet measurement of a system gives the properties of the system at the moment of observation. Any difference in dimensional properties would require a second observation. Time is always 1 or 0. The passage of time relative to the observer is the difference between the first observation and second observation of the system.
Likes cyboman
  • #66
I was rereading this thread and it's really fascinating. I wanted to apologize for the self righteous way I came off in my discussion with you PeroK. Not sure where my head was at. I mean I'm disagreeing with your perspective on something you know way way more about than me. That's a bit arrogant. I'm reading this thread and I'm sounding like a mouse arguing with an owl about the techniques for detecting small prey from far above and ideal flight approaches for capturing said prey.
Anyway, just wanted to say thanks for entertaining my ramblings and having such patience with a laymen. Your explanations were succinct and thought provoking.
Likes PeroK and phinds
  • #67
I think that those of you who are insisting that things in freefall in space follow curved lines are making the mistake of applying Euclidean Geometry in a domain where it is not relevant. Yes, in Euclidean Geometry those paths ARE curved, but so what? That is utterly irrelevant because the geometry of spacetime is not Euclidean, it is pseudo-Riemannian and in that geometry the paths are geodesics, which as has already been pointed out are considered by many to be a logical generalization of "straight line".
Likes cyboman
  • #68
Technically, I do not think this is quite the right distinction to make.
It is not the difference between Euclidean and Pseudo-Riemannian that matters. It is the difference between Euclidean and non-Euclidean. Consider special relativity (SR) for a moment. In the flat Minkowski space of SR, geodesics are straight lines. Yet this is a pseudo-Riemannian geometry.
As I know you understand already, it is not that geodesics are curved. It is the space within which they exist that is curved.
It is only when we apply a non-default metric to the space in question that the notion of curvature becomes a meaningful concept. This is perhaps more easily seen if we go back to a two dimensional analogy in a space that is not pseudo-Riemannian -- paper maps of the surface of the Earth.
If we have a flat map of the surface of the Earth this will necessarily be some sort of projection. For instance a Mercator projection. If we look at lines on the map corresponding to straight roads on the Earth, some of those lines will be curved. They will be [sections of] great circle arcs. This is reflected in the distance metric.
This "metric" amounts to a big table of distances. For any pair of points on the Earth's surface metric would tell you how far it is [along the surface] from point A to point B. For instance, 800 miles from New York to Chicago.
If you translate this metric and present it in terms of map coordinates (for instance in terms of latitude and longitude if you are using a Mercator projection) then you will find that it does not match the standard Euclidean metric. The Euclidean metric would be, for instance:$$D = 60 * \sqrt{\Delta\text{ lat}^2+\Delta\text{long}^2}$$where D is in nautical miles and lat and long are in degrees. As should be obvious, this metric matches distances measured with ruler on a flat paper map but does not match distances measured with an odometer on a real earth.
Locally on this flat paper map we will almost always be able to find a metric which fits the Euclidean form (##D^2 = \Delta x^2 + \Delta y^2##) and locally approximates the true metric. We may have to put the local x and y axes at an angle. And we may have to scale them by a constant factor, but we can still obtain something Euclidean-looking. In the case of the Mercator projection we won't have to mess with the angles of the local x and y axes. With some other projections we might need to.
[It is "almost always" because you can get coordinate singularities. In the case of the Mercator projection you get a coordinate singularity at the North and South poles. Other projections tear or irreparably stretch the map in other places]
It is a similar situation when comparing the flat space of special relativity with the curved space of general relativity. Locally you can almost always fix things up so that the Minkowski metric (##D^2 = \Delta x^2 + \Delta y^2 + \Delta z^2 - \Delta t^2##) is approximated well. One may have to scale the axes and put them at odd angles, but you can still recover something Minkowski-looking.
[Again, you can get coordinate singularities -- for instance at the event horizon of a black hole when using Schwarzschild coordinates. This is in addition to true singularities such as at the "center" of a Schwarzschild black hole]
It is possible to apply the metric (as presented in terms of map coordinates) to figure out how to extend a line on the map so that it corresponds to a straight great circle arc on the surface of the Earth. Of course, this line will not be straight on the map. But it will be straight on the surface of the Earth.
Perceived geodesic curvature is all about the projection, not about the geometry.
Note: I have never taken a course covering differential geometry. Pretty much everything think I know has been absorbed over the years here.
  • Love
Likes cyboman and phinds
  • #69
Much of this math is over my head but very fascinating nonetheless. I do like the analogy of the Earth and a map as a projection within that curved space. To us on the ground the road appears straight. But if we keep walking in that straight line, eventually we end up where we started. This reminds me of a mathematical concept I read in a fascinating book many years back. It talked about the notion of a finite but unbounded universe.
  • #70
The one where I was first introduced to the notion of curved space was "Sphereland", I think. Possibly the same one that you are alluding to.
It is difficult to properly capture the idea of intrinsic curvature. As I recall, that book did a credible job of doing so in an entertaining and understandable manner.
Likes cyboman
  • #71
The one I read was a short non-fiction about thought provoking mathematical concepts. I'll have to dig it up. I really love it I can't believe I forget the name.
I'm definitely going to have to check out Sphereland now. Thanks!
  • #72
I thought a geodesic was a vector under the effects of a motile reference frame; in the same way that Silly Puddy stretches and droops twards the Earth's center of mass, acceleration in the (SO)3 is modified by the expansion rate of space-time, effectively creating more distance the vector must traverse, the expression of which is quadrilateral movement through orthogonal space.
  • Skeptical
Likes cyboman and etotheipi
  • #74
Ahhhhh, did you study math? Cause that's over my padawan math kung fu.
Likes Delta2
