Is time measured at receding objects dilated?
  • Thread starter johne1618
  • Tags
    Time
In summary: The mathematical reality of this situation is a bit fuzzy, but I think it's safe to say that the platform would continue to expand forever.)
johne1618
371
As far as I understand it Hubble's velocity law says that the velocity v of a distant object with respect to us, at the present cosmological time, is given by
v = H_0 * r
where H_0 is the present Hubble constant and r is the distance to the object.
If a distant object is moving at velocity v with respect to us does that mean that proper time measured by an observer near that object is dilated by a gamma factor 1/sqrt(1-v^2/c^2) when measured in our time coordinates?
Space news on Phys.org
[STRIKE]Yes.[/STRIKE]
EDIT: I spoke too soon.
v = H_0 * r
Vorde said:
Yes.
I disagree, Vorde.
The present velocities given by Hubble law, for most of the galaxies we can see, are greater than c.
So the gamma factor would involve taking square root of a negative number. It would not make sense as a time dilation factor.
John, the Hubble law as you state it is v = H0r
where as you say H0 is the present value of H, and r is the present distance (which you would measure e.g. by radar if you could stop the expansion process) and v is the present rate of change of this present distance.
Most of the galaxies we currently observe have redshift z > 1.5 and any such galaxy would be presently receding at a rate faster than c.
You might find this online calculator interesting
http://www.einsteins-theory-of-relativity-4engineers.com/cosmocalc.htm
Put in a redshift like, for example 1.8 and press "calculate".
Easy to use. Where it says "Distance traveled by the light" this means the distance the light would have traveled in a non-expanding universe, on its own. It is a way of reading off the light travel time. Just read lightyears as years.
Distant galaxies do not normally share the same Lorentz frame---special rel time dilation does not apply to recession rates. It would be terrible if they did since for the most part the rates are superluminal :biggrin:
I can't argue with that logic, but it seems that if that were true, there is an experimental way to discern whether or not an object is moving away from us or the space in between is expanding, which doesn't seem right.
EDIT: Also it seems that if a galaxy were receding faster than the speed of light, a photon from that galaxy would never be able to reach us as space was expanding faster than it was approaching us.
EDIT 2: What I didn't realize until your Marcus's edit however was that a receding galaxy would not be in the same frame of reference as you however, so the SR stuff I was basing this off of is invalid, nevermind, your view is making sense to me now.
I wonder if someone could comment on this thought experiment.
I imagine constructing a very,very long rigid platform in space of length L light-years. I assume that the center of mass of the platform would travel with the "Hubble flow". Thus if I sat at the end of the platform would I see nearby objects, moving with the local Hubble flow, move past me at a velocity H_0 * (L/2) parallel to the platform?
Surely the velocity of these nearby objects relative to me would be "real" and therefore could not be greater than the speed of light?
John
This is a thought-provoking question. I think that even if one could build a super-rigid platform (or a long plank) outward at the speed of light in both directions (that is, the builders in each direction are building furiously just behind an outbound laser pulse), neither end would ever reach a location where the comoving flow (or any flow) exceeded the speed of light.
If there were "outside" builders that prefabricated and waited to join up with the growing platform, they may never be caught up to by the growing platform. That is, these outside builders may not ever be observable by us and vice-versa.
FAQ: Is time measured at receding objects dilated?
What is time dilation at receding objects?
Time dilation at receding objects is a phenomenon in which time appears to pass slower for objects that are moving away from an observer at a high velocity. This is due to the effects of special relativity, which predicts that time and space are relative to the observer's frame of reference.
How is time measured at receding objects?
Time is measured at receding objects using the same methods as for stationary objects. This can include using clocks or other timekeeping devices, or measuring the duration of events. However, due to the effects of time dilation, the measured time may appear to be slower for receding objects.
What causes time dilation at receding objects?
The cause of time dilation at receding objects is the relative motion between the object and the observer. According to special relativity, time appears to pass slower for objects that are moving away from an observer at a high velocity. This is due to the way that time and space are intertwined in the fabric of spacetime.
Is time dilation at receding objects significant?
The amount of time dilation at receding objects can vary depending on the velocity of the object and the observer's frame of reference. For everyday objects and velocities, the effects of time dilation are negligible and not noticeable. However, for objects moving at very high speeds, such as near the speed of light, the effects of time dilation can be significant.
Can time dilation at receding objects be observed?
Yes, time dilation at receding objects can be observed and has been confirmed through various experiments and observations. For example, the famous Hafele-Keating experiment showed that atomic clocks on airplanes moving at high speeds experienced a slight time dilation compared to clocks on the ground. Additionally, observations of cosmic objects, such as supernovae, have also confirmed the effects of time dilation at receding objects.
