- #36
russ_watters
Mentor
- 23,534
- 10,893
Yes, the existence of time is relevant to physics and as far as physics is concerned, time exists. The theories and their equations are based on this and they work. That's enough for physics.mangaroosh said:Just to put this in context of physics, or at least to attempt to, I will have to ask the question, as to whether or not the existence of time [as a real force/entity/etc.] is relevant to physics?
What you are asking* is a different question because what you are asking has no bearing whatsoever on the theories of physics or the outcomes of experiments. Therefore, what you are asking is not physics.
*What you are asking is, essentially, 'could the correctness of physics' treatment of time just be one big coincidence?'
Well if that can be turned into a theory, then it'll become physics. But for right now all you really have here is idle speculation about the possibility that a theory can be constructed that deals with time differently and makes new predictions not already covered by existing experiments and yet also doesn't conflict with existing experimental data.Also, to suggest that entirely new theories of physics need to be developed is not a non sequitor, as it is not suggested that the measurement that is time (as opposed to the measurement of time) be done away with. The measurement can remain, so the results can remain the same. What would be required however, is the assumption about the nature of time, that is inherent in the theory. It simply needs to be viewed differently.
I don't think you quite grasp how vast of a task it would be to rewrite all of the past 100 years of physics. Nor does it seem you understand the "if it ain't broke don't fix it" principle. Regardless: Idle speculation isn't physics either.
Call it what you want, but making correct predictions is all that is asked of a theory. Since the theories work, there is no reason to be concerned that the starting assumptions are wrong. Again, all you have here is a vague displeasure with the starting assumption but absolutely nothing of substance on which to base a challenge to it.Also, the other suggestion that because the theory has enjoyed success in its predictions, therefore the assumptions upon which it is based is correct, again, does not follow logically, as there is circular reasoning apparent within the assumption with regard to time.
How many times are you going to ask the same question and ignore the answer?With regard to the atomic clock, am I right in saying that "time" is measured based on the microwave emissions of changing electrons? Or something relatively similar? If so, why can this be said to be a measurement of the entity known as "time"?
Again, again, again, again, again, and again for the last time before the thread is locked:
Atomic clocks are not the only "clocks" we have that are capable of detecing time dilation. Therefore, you can't just assume that a cesium clock is measuring a clock error due to motion or gravity unless you assume that several other clocks that work on completely different operating principles just happen by coincidence to have the same error.
