Is (x + a + b)^7 - x^7 - a^7 - b^7 Divisible by x^2 + (a + b)x + ab?
  • Thread starter Thread starter Hyperreality
    Theorem
The problem of determining if (x + a + b)^7 - x^7 - a^7 - b^7 is divisible by x^2 + (a + b)x + ab is approached by recognizing that the factors of the divisor are (x + a) and (x + b). To prove divisibility, it is necessary to show that the expression is divisible by both factors. A suggested method involves rewriting terms and simplifying the expression. While the task may seem daunting due to the complexity of expanding a trinomial to the seventh power, it is emphasized that a systematic approach can yield results. Ultimately, the problem is solvable with careful manipulation of the algebraic expressions involved.
Hyperreality
My maths teacher says this problem is not as impossible as it seems, but I just can't solve it.
Show that (x + a + b)^7 - x^7 - a^7 - b^7 is divisble by
x^2 + (a + b)x +ab.
Mathematics news on Phys.org
Looking for the easy way out huh ?
You can always solve the entire excercise...
Live long and prosper.
Show that (x + a + b)^7 - x^7 - a^7 - b^7 is divisble by x^2 + (a + b)x +ab.
Hint:
Notice that (x+a) and (x+b) are the 2 factors of x^2 + (a + b)x +ab.
So it is equivalent to show that (x + a + b)^7 - x^7 - a^7 - b^7 is divisible by both (x+a) and (x+b).
Let f(x) = (x + a + b)^7 - x^7 - a^7 - b^7
Can you continue from here?
Hope this help. :smile:
just write everything out
eg. (x+a)^2=x^2+2xa+a^2
maybe rewrite some terms then and you will see that it is divisible by x^2 + (a + b)x +ab
KL has the easy way!
Writing it out however... *shudder* I wouldn't wish writing out a trinomial to the 7th power to anyone!
Hurkyl
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
