- #71
agentredlum
- 484
micromass said:No it doesn't. The wiki article implies that 0 is not purely imaginary. I'm pretty sure that is indeed the standard definition.
Well according to your post #11 I was starting to believe in you. Unless you disregard definitions only when it suits your argument. Now you are seeking shelter behind the definitions again.
I believe there is good reason to put the definition aside for a little while and explore consequences. I believe there is good reason to approach zero in different ways in the complex plane.
Example: If we approach 0 using a curve x^(2n +1) for large integer n then close to zero the curve 'hugs' the real axis. From the bottom on the left, from the top on the right.
If we use x^(2n) for large integer n then the curve 'hugs' the real axis from the top on both sides.
If we use y = x then it avoids both axes as I mentioned in a previous post.
