Isothermic compression question. Need help
  • Thread starter Thread starter rigger100472
    Compression
The discussion revolves around calculating heat energy transfer during isothermal compression of a gas. The key equation involved is Q = nRT ln(V2/V1), where nRT can be derived from the ideal gas law, PV = nRT. Participants clarify that for isothermal processes, the product PV remains constant, allowing for the substitution of known values to find nT. The final calculations lead to a heat transfer value of approximately 0.192. Understanding the relationship between pressure, volume, and temperature is crucial for solving the problem.
rigger100472
The question I am stuck on is "0.253 m of gas is compressed isothermally from a pressure of 1 bar until its volume is 0.0313 m. Calculate the heat energy transfer. "
I understand that work done = Heat transfer because it is isothermal but the equation I have to work with is:
Q=nRT ln V^2/V^1
I don't want the answer to this because I would like to understand, I just don't know what nRT is and how on Earth do I find T if it is not given in the answer.
I have not attempted to answer yet
rigger100472 said:
The question i am stuck on is "0.253m^3 of gas is co
What is your question?
What are your relevant equations?
Let's see your attempt at solution.
Sorry about the post being incomplete (don't know what happened). I have now edited the original post.
Hmm this question is bothering me. I definitely used to know how to do it.
I know that in an isothermal compression nRT = P1V1 = P2V2 = constant. Maybe that's how you find T, since you know P1V1 is.
EDIT: I think it is possible that this answer is correct because you're not subbing in a variable PV for NRT, you are subbing in P1V1, which are known, and known to be constant.
The basic idea that you need to understand is
W = \int^{1}_{2} P dv
P*V = n*R*T
Here n is the number of moles of the gas, R is the Boltzmann gas constant and T is the temperature. For an isothermal gas of fixed mass, n, R, and T are all constants. Therefore
P = (n*R*T) / V
\int^{1}_{2} P dv
= \int^{1}_{2} (n*R*T) / V dv
= (n*R*T)*\int^{1}_{2} 1 / V dv
= (n*R*T) * ln (v_{2}/v_{1})
Although I am not sure how you can find T, you can surely find n*T as you know the volume pressure and R you can use the equation PV = nRT to get n*T. That value you can use in your equation to find your answer
And the relationship PV = nRT comes from the ideal gas relationships which state that
\frac{P_1*V_1}{T_1} = \frac{P_2*V_2}{T_2}
As this relationship is true we can say for every mole of gas
\frac{P_1*V_1}{T_1} = \frac{P_2*V_2}{T_2} = K
This constant K is the Boltzmann gas constant R, and n is the number of moles of the gas.
Ok thanks for the info guys, I had a go at the question and this is what I came up with. What do you think?
Q=W=nRT∫_(V_2)^(V_1)▒PdV
but nRT=PV
Q=PV∫_(V_2)^(V_1)▒PdV
During isothermal compression
P_1 V_1=P_2 V_2⇒PV is a constant
In this case
PV=0.253
⇒P=PV/V=0.253/V⇒P_2=0.253/V_2 =7.167Bar
⇒Q=PV∫_(V_2)^(V_1)▒〖0.253/V dV〗
⇒Q=PV[0.253lnV]_0.0313^0.253
⇒Q=0.253(0.253ln0.253-0.253ln0.0313)
⇒Q=0.192
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
