Issue converting dV to dx dy dz
  • Thread starter Thread starter Addez123
    Dx
Addez123
Integrate the vector field
$$A = (2xy + x^2, 2 +yz, 2z^4)$$
over the sphere surface:
$$x^2+(y-1)^2+z^2 = 4$$
where y >= 0
Divergence theorem
I can calculate the divergence
$$div A = 2y + 2x + z + 8z^3$$
Now I have to integrate over this cut-off sphere.
So I decide I'll cut it up into small discs with height dy and integrate over that
$$dV = \pi(4 - (y-1)^2)^2 * dy$$
My issue here is I don't know how to integrate 2x + z + 8z^3.
Not only that but it's suppose to be a triple integral and all I get is dy..
I must have missed a step but idk which :/
There's not sufficient symmetry to use discs as volume elements, because the vector field ##\mathbf{A}## varies within each disc. Exploit the symmetry. Shift ##y' \equiv y-1## and write the resulting integral in terms of spherical coordinates (with ##dV = r^2 \sin{\theta} dr d\theta d\phi##).
Addez123 said:
Homework Statement:: Integrate the vector field
where y >= 0
Relevant Equations:: Divergence theorem
dV=π(4−(y−1)2)2∗dy
This is not dV. It is dV integrated over the x and z coordinates assuming that the integrand does not depend on them. (Assuming you get rid of that additional square you inserted.)
However, there may be a way to get rid of that pesky x and z dependence if you think a few extra times before writing down the integral.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
