It seems like it's simple math but I'm not sure?
  • Thread starter Thread starter lesdayy
The discussion centers on calculating the final temperature when mixing two liquids, specifically a 300 g cup of coffee at 90°C and 30 g of cold water at 10°C. It emphasizes that the temperature change can be calculated using either Celsius or Kelvin, as the results will be the same. The final temperature must fall between the two initial temperatures, suggesting an averaging approach. There is a debate about the necessity of understanding the physical principles of temperature alongside the mathematical calculations. Ultimately, grasping both the concept and the math is essential for accurate results.
lesdayy
A 300 g cup of coffee at 90°C is too hot to drink, so a person puts in a 30 g of cold water at 10ºC. What will the final temperature be? (Hint: you don't actually have to calculate, think about the range the temp would have to be in)
I dont believe there is one. I tried just simple math but it seems to good to be true
I don't believe there is one. I tried just simple math but it seems to good to be true.
There is a relevant equation. Can you name it?
Which temperature scale should you use when calculating the new temperature? :wink:
Edit/Update -- As long as you are just calculating the *change* in temperature from mixing the two liquid samples, then I don't think it matters if you think about it in terms of Celsius or Kelvin. When finding the ##\Delta T## change in temperature the results should be the same.
Start with the realization suggested by the hint: the final temperature cannot be greater than 90°C or less than 10°C. It has to be in-between, i.e. some kind of average. What kind of average? If I gave a test and 300 students got a score of 90 and 30 students got a score of 10, what would the average score be?
It's amazing how something familiar becomes unfamiliar when seen in a new context, isn't it?
lesdayy said:
Homework Statement:: A 300 g cup of coffee at 90°C is too hot to drink, so a person puts in a 30 g of cold water at 10ºC. What will the final temperature be? (Hint: you don't actually have to calculate ...
I don't really agree with this. You need a physical understanding of what is temperature and some mathematics to support that model. The calculations may be easy once you have those things, but everything is linear!
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
