IUPAC dilemma on naming a toxin, any pro organic chemists out there?
  • Thread starter Thread starter Whakataku
    Iupac Organic
The discussion centers on the IUPAC naming of Batrachotoxinin A, a toxin that has not been previously assigned an official name. The participant initially considers using a name derived from its relative, Batrachotoxin, but realizes that Batrachotoxinin A lacks a carboxylic acid group and instead contains a hydroxy group, indicating it should be classified differently. After some deliberation, the participant arrives at a new IUPAC name for Batrachotoxinin A, which reflects its structural modifications, specifically noting the presence of a substituted ethanol. The final name emphasizes the unique features of the compound, including its stereochemistry and functional groups.
Whakataku
So I came across a cool toxin, and saw that people have not assigned an IUPAC name to it, so I took on the challenge.
The compound of interest is Batrachotoxinin A
unc.
edu/depts/mtcgroup/litmeetings/batrachotoxinin.pdf
In the second slide Batrachotoxinin A has an R which is an H instead of a pyrolle moiety.
Now Batrachotoxinin A's relative Batrachotoxin (the one with the pyrolle moiety) has the following IUPAC name
1H-Pyrrole-3-carboxylic acid, 2,4-dimethyl-, (1S)-1-[(5aR, 7aR, 9R, 11aS, 11bS, 12R, 13aR)-1,2,3,4,7a,8,9,10,11,11a , 12,13- dodecahydro-9,12-dihydroxy-2, 11a-dimethyl- 7H-9,11b-epoxy-13a, 5a-propenophenanthro[2,1-f] [1,4] oxazepin-14-yl] ethyl ester
So is the Batrachotoxinin A's IUPAC
(As you can see I just deleted 1H-Pyrrole-3-carboxylic acid, 2,4-dimethyl-,)
is that ok?
Chemistry news on Phys.org
Wait I take that Batrachotoxinin A does not have carboxylic acid any more, but a hydroxy group, so it's not an ester, but an alcohol.
So I somehow have to name it with a substituted ethanol??
Any hints??
Never mind, I found the name:
[5\alphaR-[5\alpha\alpha,7\alpha\beta,9\alpha,11\alpha\beta,11\beta\alpha,12\alpha,13\alpha\alpha,14(S*)]]-1,2,3,4,7a,10,11,11\alpha,12,13-Decahydro-14-(1-hydroxyethyl)-2,11\alpha-dimethyl-7H-9,11\beta-epoxy-13\alpha,5\alpha-propenophenanthro[2,1-f][1,4]oxazepine-9,12(8H)-diol
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
