IV curve of a BD-5 tunnel diode
  • Thread starter Thread starter jack b
    Curve Diode
The discussion revolves around the search for the IV curve of a General Electric BD-5 tunnel diode. Jack initially sought existing data but found only limited resources and considered measuring it himself. A participant provided a link to a sketch of the curve but acknowledged it lacked detail. Ultimately, Jack measured the IV curves of the BD-5 and BD-4 diodes using a SourceMeter and shared his findings with the community. The thread highlights the challenges of obtaining specific electronic component data and the value of community contributions.
jack b
Hi All
Anyone know where I might find the IV curve for a General Electric BD-5 tunnel diode? I have found a few short datasheets for the BD series, but I really need a curve.
Does anyone know where to find such a thing? Or should I just get the SourceMeter out and make one myself.
Thanks
Jack
jack b said:
Hi All
Thanks
Jack
I googled BD-5 tunnel diode, and got some hits. Here's one with a sketch of the curve:
http://www.phys.ufl.edu/REU/1999/reports/tyner/tyner.htm
from a report on some research.
It may be the most effective like you say to just sweep out the curve yourself. If you're in Silicon Valley, I have a curve tracer next to my lab bench that I could let you use...
Hi Berkeman
Sorry for the delay in replying, I ended up traveling home for christmas, so no internet.
Cheers for looking, but that doesn't really have the detail I need. And I'm a few thousand miles too far east to take up your generous offer to lend a curve tracer. I managed to borrow a good Keithley SourceMeter, so I'll just do the measurements back at the lab.
Thanks anyway
Jack
Side note: One of my first assignments at my work was sweep out the I-V curves for several zener diodes. We didn't have a curve tracer readily available, so I had to build a test jig using only a power supply and a resistor.
EDIT: OK, so I was replying to a post pushing some curvefitting software, which got deleted as spam, but I'll leave my post here as the info may be useful.
Ignoring the fact that this thread has been dead for months, and the fact that a lorentzian fit to a badly-sketched curve without any values on it would be about as much use as a water soluble lifeboat, I do now have some useful data.
For anyone who's interested I did take appropriate data back in February. I thought I'd make it available to anyone who's searching the web for it.
I've attatched rough IV plots of two BD5 diodes and a BD4 diode, measured with a sourcemeter at room temperature. Usual disclamers apply (not all the diodes are the same, for all you know I'm incompetent etc. etc.)
Cheers
Jack
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
