Japan Earthquake: Nuclear Plants at Fukushima Daiichi
In summary: RCIC consists of a series of pumps, valves, and manifolds that allow coolant to be circulated around the reactor pressure vessel in the event of a loss of the main feedwater supply.In summary, the earthquake and tsunami may have caused a loss of coolant at the Fukushima Daiichi NPP, which could lead to a meltdown. The system for cooling the reactor core is designed to kick in in the event of a loss of feedwater, and fortunately this appears not to have happened yet.
  • #5,286
Features of the unit 3 explosion
0.0 - 0.4 | a detonation with a flash of fire from SE corner
0.4 - 3.5 | an expulsion of water/water vapor from center/SE of building
0.4 - 6.4 | a high buoyancy airmass rises vertically, dark and debris-filled eventually reaching a height of 500+ m
This goes back to the previous question: the building implodes a fraction of a second before the detonation, the hypothetical explanation for that which makes the most sense to me thus far is that the oxygen inside the building is being consumed by the ignition of the hydrogen
And then this part from Dimytri
Moreover, if the fire becomes oxygen-starved (quite probable for a fire located in the bottom of a pit such as this), the hot zirconium would rob oxygen from the uranium dioxide fuel, forming a liquid mixture of metallic uranium, zirconium, oxidized zirconium, and dissolved uranium dioxide. This would cause a release of fission products from the fuel matrix quite comparable to that of molten fuel
What is it that detonated in the Spent Fuel Pool #3? Would the oxygen in the building being consumed by combustion have any effect on a molten mixture in the bottom of the pool?
  • #5,287
Danuta said:
Yeah, there were only two guys who came last time. I guess the info given out at these press conferences is leaving more than seats empty.
Well if they take questions, we need the contact addresses of those two to send them questions to ask
  • #5,288
Oak Ridge National Lab analyzed a Station Blackout (SBO) at Browns Ferry (BWR4, Mark1) back in 1981.
http://www.ornl.gov/info/reports/1981/3445600211884.pdf
While this is 30 years old (I assume both their modeling and modifications to the plant have improved the scenario), it paints an unpretty picture of the realities Tepco faced. In regards to the loss of injection sources caused by VDC exhaustion:
"results predict core uncovery 62 minutes after the beginning of boiloff, followed by the inception of core melting 53 minutes later. The model provides that the melted core slumps down to the bottom of the reactor vessel and this results in a predicted failure of the reactor vessel bottom head at approximately three hours after injection capability is lost."
I haven't had time to get through the whole document, but the summary is eye opening itself and has already cleared up a few of my questions. One thing that comes to mind is the explosive venting of Unit 2's Torus:
"the operator loses manual control of the SRVs. The long term result is that a single SRV will continually open into the PSP. The local fluid temperature will monotonically rise, resulting in pressurization of the torus and possible condensation oscillations. The potential exists for rupture of the torus due to overpressure coupled with violent pressure oscillations."
Or was it hydrogen? Interesting nonetheless.
  • #5,291
I have seen no evidence of an initial implosion. The video frames of the unscathed building appear to me to be dead steady right up to the first frame showing a flash & an explosion.
That an implosion could be produced by ignition of hydrogen in air also does not make sense from a theoretical standpoint. True, in the chemical reaction during hydrogen combustion in air, 3 molecules will be consumed for each 2 molecules created, which looked at in isolation at equilibrium would lead to a pressure drop which theoretically could get as high as 20 kPa, but I am pretty sure these buildings would not implode under such minor suction. And that's disregarding that the process is highly exothermic so that the two molecules created will come out of the process with much more kinetic energy than the three molecules consumed, yielding initially a high net increase in pressure.
I don't think anything detonated in the SFP as such, and even if something did detonate somewhere, as something obviously did, that could hardly
deprive anything of oxygen for very long, seeing that a detonation inside these buildings blows out walls, letting in lots of fresh air..
  • #5,292
Some notes about the water level/radiation in the unit 4 basement:
http://search.japantimes.co.jp/cgi-bin/nn20110329a1.html
According to this source the level of water was +80 cm in the unit 4's turbine building. (dated March 29)
http://english.kyodonews.jp/news/2011/03/81375.html
According to this source the level of radiation was less than in unit 1, 2 and 3. (dated March 28)
http://www.world-nuclear-news.org/RS_Contaminated_pools_to_the_drained_2703111.html
The radiation in the unit 1 turbine building was 60 mSv/h. (dated March 27)
So the conclusion is that around 27th - 29th of March the water level in the unit 4's turbine building was +80 cm and radiation less than 60 mSv/h.
http://www.asahi.com/english/TKY201104190193.html
In this source they are saying that level of water was +500 cm and radiation 100 mSv/h in the basement of the building housing the unit 4 reactor. (dated 20th of April)
To me it's unclear if they are talking about the same spot.
If so the conclusion is that during March 27th/29th - April 20th the water level has risen from +80 cm to +500 cm and radiation from < 60 mSv/h to 100 mSv/h.
Any other interpretations?
  • #5,293
They aren't, the turbine building and the reactor building are two different buildings.
  • #5,294
Okay, immediately after mensioning "the basement of the building housing" (unit 4) the reporter starts talking about unit 1 - 3's turbine buildings' basements. I had this feeling that the reported might have made a mistake and was really talking about the same buildings. Any chance of mistake here?
Officials of the Nuclear and Industrial Safety Agency (NISA) said April 18 that a pool of water about five meters deep had been found in the basement of the building housing the No. 4 reactor.
Radiation levels as high as 100 millisieverts per hour were detected on the water's surface.
About 54,000 tons of radiation-contaminated water also sits in the basements of the turbine buildings for the No. 1 to No. 3 reactors.
  • #5,295
A message to Jorge Stolfi: as you spent a good time in the modelization of the buildings and reviewed some of the drawings available, if you have a chance to modelize also the turbine buildings maybe you could do a rough estimate of the volume that can be contained in the basements of the turbine buildings (so below the level of the platform ground)? Of course this volume depends on the heights, the length and width of these buildings, but the general layout of the rooms, the thickness of the walls and of course the volume occupied by the machinery is also a factor for the final estimate (for this we can evaluate it by a certain percentage, based on experience of some people on this forum maybe?).
It would be interesting to know what is the water containment capacity in thousands of m3 of these buildings (even a rough estimate).
The fact that these basements are below the ground at least help to somewhat contain the flow of cooling water (highly contaminated) to avoid a direct reject into the see (but anyway this containment cannot be perfect, and we already know it is clearly leaking as there is a fair contamination in the sub drains, probably also in the ground water and so probably also in the discharge flow of phreatic groundwater into the sea).
  • #5,296
http://www.foxbusiness.com/industries/2011/04/18/japan-nuclear-agency-reactor-building-4s-basement-filled-meters-water/
"It was the first time that the agency released the extent of flooding in any of the reactor buildings. The flooding situation in the Nos. 1-3 reactor buildings is not known, Nishiyama said.<..> Nishiyama also said the basement of the turbine building of the No. 4 reactor also has about a meter of water."
  • #5,297
MadderDoc said:
triumph61 appears to me to be saying that since core shroud replacement was in progress, the reactor was likely not flooded at the time of the earthquake
According to TEPCO, it was:
http://www.yomiuri.co.jp/feature/20110316-866921/news/20110428-OYT1T00663.htm
(Repeat of link from my post a couple of pages back in this thread.)
Add: See following post by clancy688 for link to English version (without diagram) of the same article.
  • #5,298
http://www.yomiuri.co.jp/dy/national/T110428006723.htm
A hydrogen gas explosion at the No. 4 reactor of the Fukushima No. 1 nuclear power plant on March 15 may have helped prevent spent fuel rods from melting down by causing a flow of water into the pool the rods are stored in, according to research by Tokyo Electric Power Co.
It seems that shocks from the explosion damaged a water gate and caused water to flow into the pool from a neighboring part of the facility, TEPCO said.
Wow. Just wow. They and every city in the surrounding prefectures were indeed SAVED by the explosion of the reactor building. Apparently god has a somehow twisted sense of humor...
  • #5,299
Indeed, Tepco's having the theory, that water may have overflowed from the reactor cavity into the SFP after an explosion damaged the gate certainly implies that Tepco must know the cavity to be water-filled at the time of explosion. The theory seems to be fed by a suspicion that water fed to the SFP now overflows back into the reactor. One cannot have it both ways, I think, unless the same explosion which so very fortunately damaged the gate such that a disastrous fire could be averted, unfortunately also made the reactor leak. Good news/bad news.
Here's a link to Yomiuri's English translation of the original article:
  • #5,300
Toshiba web page describing what happens during a core shroud replacement.
http://www.toshiba.co.jp/nuclearenergy/english/maintenance/replace/shroud03.htm
Initially the RPV is filled with water. In later stages, the RPV is empty. It sounds like a milling machine works underwater and takes off metal at some point to reduce the radiation. The shavings are then removed to the equipment pool. That may explain the thermal images we saw that implied the reactor well was hot.
http://www.irpa.net/irpa10/cdrom/00584.pdf
Further describes the chemical and mechanical decontamination at Unit 2 when its core shroud was replaced years ago.
What I don't understand is if it's possible to decontaminate the inside of a reactor this way, why is it necessary to put decommissioned reactors into SAFSTOR mode for decades? Why not just decontaminate them, cut them up into pieces, and dispose of them?
  • #5,301
Discovery Channel Special on Japan's Nuclear Crisis TONIGHT - 10:00pm eastern April 28, 2011 http://dsc.discovery.com/tv-schedules/special.html?paid=1.14144.26383.0.0
  • #5,302
AtomicWombat said:
The radiation measurment rose after the start of N2 injection. N2 injection will do 2 things 1) stir up the contents of wherever it's being injected; and 2) create void space.
Void space in the water will reduce shielding from the radiation sources. Stirring could spread the radiation around.
All this is speculation. I don't even know whether the N2 is injected into the RPV or dry-well.
This could be the source of high radiation increase fresh water and the Oxygen 16 to Nitrogen 16 activation via fast neutrons. Though short lived the resultant gama from its decay is very strong.
Radioisotope 16N is the dominant radionuclide in the coolant of pressurized water reactors or boiling water reactors during normal operation. It is produced from 16O (in water) via (n,p) reaction. It has a short half-life of about 7.1 s, but during its decay back to 16O produces high-energy gamma radiation (5 to 7 MeV).
  • #5,303
Decontamination of the RPV interior surface just removed radioactive surface corrosion/wear particles adhered to it. The RPV is still irradiated/radioactive and shielding is still needed for workers on the support platform.
  • #5,304
This how it's supposed to work -
http://www.world-nuclear-news.org/RS_Browns_Ferry_hit_by_major_storms_2804112.html
TVA said it had never experienced anything like the passage of several storm systems through its 80,000 square mile service area. Each one caused more damage to transmission lines until over 100 transmission elements were knocked out and some 677,000 homes left without power.
The three boiling water reactors at TVA's Browns Ferry nuclear power plant in Alabama shut down automatically with cooling systems powered by "a combination of offsite transmission and on-site diesel generators." However, the shutdown was notified as an 'unusual event' to the Nuclear Regulatory Commission "when the normal and alternate power supplies for essential equipment were unavailable for more than 15 minutes." TVA stressed that "safety systems performed well."
They have one line intact, and their 8 EDGs are available.
  • #5,305
jlduh said:
A message to Jorge Stolfi: as you spent a good time in the modelization of the buildings and reviewed some of the drawings available, if you have a chance to modelize also the turbine buildings maybe you could do a rough estimate of the volume that can be contained in the basements of the turbine buildings (so below the level of the platform ground)? .
For that one would need diagrams of the turbine building, with reliable dimensions and/or scale. It was already so hard to get those reactor blueprints, and they are still missing many important details...
Moreover I will be rather busy until next week. Anyway, if you manage to get the blueprints, computing the rom volumes by hand is much easier than modeling them with POV-Ray (which in fact does not have a 'volume' function).
  • #5,306
Thanks, I see that now. Even though the workers were able to work without respirators, they still needed a bunch of lead shielding before they could go inside.
  • #5,308
I would rate it 4/10 based on the fact that I watched it with someone who has not been following the situation as closely as I have, and she was more confused about the entire situation after watching it than she was before.
I saw some photos that I don't recall seeing yet anywhere else. Other than that... meh. It served up the "Fukushima 50" as heroes and perpetuated the myth of workers cutting a hole in the side of Unit 2 after Unit 3 exploded. It did pose a few unanswered and insightful questions about the future of the entire area around the plant.
About a third of it dealt with the general devastation left behind by the earthquake and tsunami. That part was actually interesting, even though it was obviously influenced by the presence of a young and attractive American woman who was up the coast trying to save the whales. She was touched that some of the Japanese people they encountered offered her and her companions food to eat on their treacherous hike away from the coast in search of a ride to the airport.
They had comments from Lochbaum and a few others. Thankfully they did not talk to Gundersen. The show as a whole was not a scientific look into the problems at Fukushima Daiichi. It was more of a "human interest" piece so typical of American television. The message at the end was, "They will eventually get it sorted out."
Better than nothing I guess. If you didn't see it you didn't miss much.
  • #5,309
Due to my diligence in following this topic I spotted many mistakes made in the broadcast.
  • #5,310
A few new photos - debris clean-up operation, T-hawk, robots, salvage in exclusion zone:
http://cryptome.org/eyeball/daiichi-npp13/daiichi-photos13.htm"
  • #5,311
Greetings from a first time poster! I found this forum by googling "physicsforums" with "forensic analysis" after someone had alerted me to its existence, and I have taken the time to read (well, in many cases perhaps just skim) all 5000+ posts here. I am impressed by both the educated speculation that is naturally based on limited evidence and the honest critique of all speculation in accordance to the principles of the scientific method. According to Google this thread has been mentioned in other forums as a high quality resource, and I would like to express my appreciation for the time and expertise people have been offering to make it such.
Since I have nothing of substance to post at this time I will permit myself to recede into the background and keep reading along.
  • #5,312
I guess two men was Japanese.
  • #5,313
Okay, thanks MadderDoc.
So it was +80 cm, < 60 mSv/h in the basement of the turbine building.
And now +500 cm, 100 mSv/h in the basement of the reactor building.
  • #5,314
I think the first picture gives a good view of where the staircase leading to the 'hole' on #4 was.
  • #5,315
So TEPCO says SFP 4 is not leaking:
The company checked the reactor facilities, suspecting water might be leaking from the pool, but cannot confirm water leakage into the bottom structures of the reactor building.
If we take the best option and guess that RPV is not leaking either the question remains where has this +500 cm/100 mSv/h of water in the basement come from?
I can think of two possibilities:
1. It's the result of all the sprayed water into the SFP that has missed the target or overflown.
2. Some of it might be tsunami waters coming from outside in.
  • #5,316
It also shows that what appeared to be some Dark Goo streaming down the wall from the terrace is actually a bunch of cables. Some random comments about this old photo, based on the blueprints:
[PLAIN]http://www.ic.unicamp.br/~stolfi/EXPORT/projects/fukushima/povray/blueprint/foto/edited/out/reactor4-S-1-A-i.png
(A larger version is http://www.ic.unicamp.br/~stolfi/EXPORT/projects/fukushima/povray/blueprint/foto/edited/out/reactor4-S-1-A-e.png" .)
A - Wall sections pushed out by the explosion. Same pattern on the other side of the entrance gallery. (Why only the sections on the far end of the gallery?)
B - Markings left by the external staircase. It seems that the staircase was still there after the earthquake but before the explosion. Where did it go? is it buried under the rubble, or was it removed by workers early on?
C,D,E - Approximate levels of floors 5 (service), 4, and 3, respectively.
F - Outline of the SFP projected on the south face. The SFP cavity begins about 6.4 meters north of the south façade, and its internal dimensions are ~ 13.2 m E-W, ~10 m N-S. These numbers are my estimates assuming the drawings I have are correctly scaled. One of the drawings gives the total depth of the SFP as 13.020 meters.
G - Original locations of pillars 2, 3, and 4 on the South face. (Pillars 2 and 4 are aligned with the tracks of the FHM and probably are there to help support the SFP. Pillar 3 is aligned with the reactor axis. Pillar 4 was twice as wide as the others.)
H - apparently, the original location of the Mysterious Green Box, that seems to have disappeared after the earthquake, uncovering the Door With Mickey Mouse Ears.
I - A huge grenish "closet", flush against that wall. The dark bands above it, leading to the terrace, are bundles of cables or pipes. Is that the Mysterious Green Box? Too big for that?
  • #5,317
Ok Jorge, i was just asking in case you would have some more prints or data. I only have two sketches that have been posted here maybe a month ago, especially one that i captured from an NHK news program which is a transversal cut of the all building (East/West).
Could you confirm me two numbers:
1) the depth of the floor basement in the reactor building, below the line of the platflorm ground? (probably n°1 is different because it is a different reactor, but 2 to 4 should be similar). It should be something like 11 meters i think but maybe you can confirm this. The depth of the basement of T/B seems aligned with the one of the R/B so this info could help me to check and scale the sketch i captured on the NHK.
2) seen from the top, and also for scaling purposes, the exact outside dimensions of the R/B 1 to 4 (1 is a little bit smaller maybe)?
I will see if i can try to estimate some rough volume of the basements we are talking about.
  • #5,318
Hey Jorge Stolfi, you seem to know your building elevations so...if the RPV cap at the join to the vessel leaks and vents, what level or plane would it be projecting or slicing through in relation to Unit 3? Or if you cut the Unit 3 down to the elevation level with the RPV flange (like cap removed), what would it look like on your modeling?
  • #5,319
TEPCO's theory certainly explains a lot of things. But I am still curious:
rowmag said:
What is not discussed is how this squares with their earlier measurements of the water contamination, which indicated insufficient fuel rod damage to explain hydrogen generation. Could those measurements now be explained by dilution, since the water volume is now effectively much bigger (including the reactor vessel, and possibly the equipment storage pool on the other side if that gate was also damaged) than was being considered before (just the SFP)? Or can you get hydrogen generated before the zircaloy heats up enough to crack?
Anyone? (NUCENG? Astronuc?)
  • #5,320
cant confirm but can't deny also... so who know, I don't believe in miracles, if they were injecting 70t per day and it was ok so why they chang it to 200t per day now ? Tsunami water shouldn't enter reactor building, it should be sealed, also I don't think that so much water missing SFP during injection, also water is radioactive so it can't be from tsunami
47K
433K
266K
15K
11K
