- #8,646
Jorge Stolfi
- 279
jim hardy said:Jorge on the anomalous pressure readings around 21 March, from my recollections at the time (i noticed it too): I think they were inferring pressure from a gage on a pipe through which they were pumping water. Possibly a gage on a fire truck pump.
Good explanation, thanks!jim hardy said:There's one more failure mode, wet insulation.
Being dissimilar metals [...] they'll also make a battery if placed in an electrolyte. That electrochemical effect makes tens of millivolts and will cause substantial error if the insulation gets compromised and water gets to the conductors. The chemical millivolts overwhelm and bury the temperature microvolts. [...] Given all the steam in there it could be a wet terminal block in a flooded junction box. Might dry out and start working on its own.
One thing I don't understand about theormocouples is why the bimetal wires are usually extended all the way to the voltmeter. Why couldn't they be extended only to some cooler place nearby (such as just outside the concrete enclosure), and then have the signal be carried by copper wires to the meter? That would result in lower resistance for the signal and reduced risk of electrochemical effects along the way.
Or is that in fact how it is done?
jim hardy said:About a month ago i posted some thoughts about unit 3 and your charts here,
http://tickerforum.org/akcs-www?singlepost=2541679
at time i thought the rpv and containment were both open at top. Less convinced of that now.
Thanks for the compliments and for the thorough analysis. As for them being "open", there is a continuum between having a small leak and being wide open, so it may not be a simple yes/no question. Also, for a small leak, the degree of opening may be sensitive to pressure, temperature, flooding, clogging, etc., and so may vary erratically with time.
Thanks! I think I saw mention of it in this forum, but hadn't the time to check it out then.SteveElbows said:As part of the same release of data some weeks back, there was temperature data in another file, covering a similar time period. This is the file for reactor 3:
http://www.tepco.co.jp/nu/fukushima-np/f1/images/syusei_temp_data_3u.pdf
Thanks again. I am tempted to include those readings in my plots too, but first one question: do they reflect the conditions inside the reactor, or only of the external contamination? In other words, are those gammas and neutrons mostly created by fission and decay inside the reactor's concrete enclosure? If so, does the spent fuel in the SFP contribute to those readings?SteveElbows said:[Gamma and neutron] data has long been available [...]
http://www.tepco.co.jp/en/press/corp-com/release/betu11_e/images/110528e14.pdf
Thanks, that is important information.NUCENG said:For information, RPV Pressure instruments sense steam dome pressure on the reactor water level condensing chamber instrument tap outside of the shroud and dryer skirt at about the elevation of the tops of the steam separators. The instruments themselves are in the reactor building outside of containment'
As for the temperature sensors, I have seen several diagrams showing their approximate location on the RPV, drywell and torus; but I still miss the key details. Namely, where precisely are the RPV temperature measured: on the outside surface of the RPV, or embedded into its wall? If the former, woud the reading be affected by the drywell atmosphere or by water leaks above the sensor? How far is the "water nozzle" temperature sensor from the nozzles and their feedpipes? And so on...
These details are important, for example, to analyze the pressure x temperature plots. The red boiling curve in those plots is relevant only if the temperature and pressure are measured at the same spot in the fluid. Barring gauge malfunctions, the pressure must be indeed that of the fluid at the gauge's intake point, which should be valid for the bulk space inside (except for the hydrostatic pressure gradient in the liquid-filled part). On the other hand, if the temperature is measured on the outside of a 15 cm thick wall, or even embedded into it, it will be some value intermediate between the temperatures of the two fluids in immediate contact with the wall. Thus, one can easily have superheated steam inside the RPV with a temperature reading well below the boiling curve, or (less likely) liquid water inside with a temperature reading well above the boiling curve.
