Just a quicky (Schrodinger's equation)
The discussion revolves around demonstrating that the probability per unit length of finding a particle is constant, independent of space and time, using the plane wave state ψ(x) = exp(ikx). Participants clarify that when calculating the probability density, the time-dependent part of the wavefunction, exp(-iEt/ħ), does not affect the modulus squared, leading to the conclusion that the probability density is simply |ψ(x)|². There is confusion about the nature of complex numbers and the interpretation of the modulus, with emphasis on the fact that the phase does not impact the probability density. Ultimately, the discussion highlights the importance of understanding complex analysis in quantum mechanics to grasp these concepts fully.
DanAbnormal
Currently I am doing a question where its asked me to show that the probability per unit length of finding a particle is independent of space and time, and is just a constant.
The plane wave state I've been given to solve is:
\psi(x) = exp(ikx)
I separated the variables of the SE and got a formula for \Psi(x,t) = \psi(x)exp(-iEt/hbar)
Assume lowercase psi here is constant, i can't be bothered to write it out :P
Obviously the probability per unit length is the square of the modulus of this function.
For some reason it shows in my notes that when you do this, the exponential part of the wavefunction dissapears when you do the square of the modulus, so you are just left with the square of the modulus of psi.
Now that would leave me with the answer, as I've already worked out psi is a constant independent of x, but I can't figure out why the exponential part dissapears. Is it just some basic maths that I am not getting here?
Well for one, you already know \psiisn't constant from the fact that you already have \psi (x) = e^{ikx}. The reason the exponential with the energy goes away is when you take the conjugate of \Psi, you take the conjugate of \psi along with the conjugate of e^{-iEt/\hbar } which will eliminate the time evolution term.
DanAbnormal said:
... show that the probability per unit length of finding a particle is independent of space and time, ...
\psi(x) = exp(ikx)
What do you mean, "solve". In what sense is the plane wave state unsolved?
I presume that the potential term in your SE is constant?
Please explain why that is obvious. That is nothing more than an interpretation of nonrelativistic QM, and it follows from nothing. There are in fact QM interpretations in which this is not true.
This is a rather round about way of saying ... something ... but I did not quite follow. I think what you are trying to say is that the modulus of a complex number is independent of its phase.
DanAbnormal said:
... psi is a constant independent of x, ...
No, it's not! What are you talking about?
Indeed: complex analysis. Do you know what a complex number is?
Oh sorry, the question asks me to show that \psi(x) = exp(ikx) is a solution of the time-independent schrodinger equation.
The potential is zero, yes. So I get the equation for Psi as:
\Psi(x,t) = \exp(ikx).exp(-iEt/\hbar)
From the separation of variables stuff.
Well yeah ok, its not obvious on that sort of scope, I am just doing an exam paper here.
The question asks me to work out the energy in terms of k, having shown that \psi(x) = exp(ikx) is a solution to the TISE.
By mistake I've assumed this energy, which is constant, was the same value as \psi(x). This is obviously wrong which I've realized.
The energy I worked out was
E = \frac{\hbar^{2}k^{2}}{2m}
I shouldn't have said "obvious", but the probability per unit length is |\Psi(x,t)|^{2}, is it not?
Well I don't know, i'll show you exactly what I am talking about:
|\Psi(x,t)|^{2} = |exp(-iEt/\hbar)|^{2}.|\psi(x)|^{2}<br /> = |\psi(x)|^{2}
I didnt understand why this was so.
Yeah this follows on from my previous mistake, assuming that smal phi was the energy constant above.
The question says: "What is the corresponding time-dependent solution,
\Psi(x,t)?
Show that the probability per unit length of finding a particle is constant (independent of both space and time)."
This, I assume is where the above workings come into place, basically showing that
|\Psi(x,t)|^{2} is constant. Is this right?
Yes of course, but I am unfamiliar with what's going on with this modulus business.
Where I am confused now is that how can the probability per unit length be constant if these complex terms are dissapearing? Wouldnt |\psi(x)|^{2} disappear also? And even if it didnt how can it be independent of space?
Can you explain to me or link me to somewhere which explains this:
Actually, no. If that were true, then what would you get for the total probability of finding the particle in a length L, where L here is an arbitrary length? (Please calculate this and report back.)
The squared modulus is usually interpretted as proportional to probability density, and, when properly normalized, it is equal to probability density. Based on the result of the previous excercise, what normalization constant should you divide by in order to interpret the squared modulus of a free particle wave function as a probability density?
DanAbnormal said:
|exp(-iEt/\hbar)|^{2}.|\psi(x)|^{2}= |\psi(x)|^{2}[/tex]
... I am unfamiliar with what's going on with this modulus business.
You cannot understand ordinary QM without understanding this.
Complex terms are not disappearing; imaginary terms are cancelling.
|\Psi(x,t)|^{2} = |exp(-iEt/\hbar)|^{2}.|\psi(x)|^{2} = |\psi(x)|^{2}
Do you understand that |e| = 1 , where φ is any arbitrary real number? Look up Euler's identity.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
