Just wondering, how do you combine series?
  • Thread starter Thread starter johnny872005
    Series
To combine series of springs, the formula for springs in series is 1/k(total) = 1/k1 + 1/k2, which leads to k(total) being less than either k1 or k2. In contrast, when springs are arranged in parallel, the combined spring constant is simply the sum of the individual constants, k(total) = k1 + k2. The discussion highlights a common misconception that springs in series can be added directly. The correct approach depends on the arrangement of the springs, whether in series or parallel. Understanding these principles is crucial for solving physics problems related to spring constants.
johnny872005
just wondering, how do you combine series? I believe that springs and circuits are done the same way.
If I am combining 2 spring constants for the combined constant, isn't it just
1/k(constant) = 1/k1 + 1/k2 and just solve for k?
wouldn't that just end up being k(constant)=k1+k2?
and hey! I think I'm in your class: Kenneth Gentle, PHY 301, University of Texas?
just kidding! --> it doesn't end up being k=k1+k2
(DUH)
If all of the springs are on a line, the constants is
\frac{1}{k_1}+\frac{1}{2}+...+\frac{1}{k_n}
And if all of the springs are parallel each other, the constant is
k=k_1+k_2+...+k_n[/color]
nope, I got fitzpatrik phy 317k at UT ;)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
