MHB Justify $\Theta(n^7 \log n)$ for $g(n)$
  • Thread starter Thread starter evinda
The discussion focuses on determining the asymptotic complexity of the function g(n) = 8n^7 log n + 18 log 13 + 16 log n^n + 12 n^(5/2). It is established that the dominant term is n^7 log n, leading to the conclusion that g(n) = Θ(n^7 log n). Participants verify this by showing that all other terms in g(n) are asymptotically smaller than n^7 log n for sufficiently large n. They confirm that for n ≥ 2, each term is less than or equal to n^7 log n, justifying the Θ notation. The discussion emphasizes the importance of identifying the dominant term and verifying the conditions for Θ notation.
evinda
MHB
Hi! (Smile)
I want to find the asymptotic complexity ($\Theta$) of the function $g(n)=8n^7 \log n+18 \log{13}+16 \log n^n+12 n^{\frac{5}{2}}$.
We see that the dominant term is $n^7 \log n$, but how could we justify it? (Thinking)
Does this mean that : $g(n)=\Theta(n^7 \log n)$ ? :confused:
Technology news on Phys.org
According to definition we have to find constants such that
$$c_1 f(n) \leq g(n) \leq c_2 f(n) $$
is held true for all $n\geq N_0$ , Can you find such constants ?
Yes, but.. how can I explain that $n^7 \log n$ is the dominant term? (Thinking)
You can try to verify it by definition, that is,
$$g(n) = \Theta(n^7 \log n) \Leftrightarrow \exists c>0, \exists n_0 \in \mathbb{N}, \forall n \geq n_0: 0 \leq g(n) \leq c n^7 \log n$$
I would do the following: try to show that all terms (with exception of the first term obviously) of $g(n)$ are smaller than $n^7 \log n$ for a certain $n_0 \in \mathbb{N}$.
First, note that $\forall n \geq 2: 18 \log 13 \leq n^7 \log n$. This follows from the fact that $\log n$ and $n^7$ are increasing functions forall $n \in \mathbb{N}_0$.
Second, we can write $16 \log n^n = 16n \log n$. We want to search for which values of $n \in \mathbb{N}_0$ we have: $16 n \log n \leq n^7 \log n$ or equivalently $16 n \leq n^7$. Since $n^7$ increases much faster than $16n$ for the natural numbers (without zero) we can conlude that $\forall n \geq 2: 16n \leq n^7$, therefore $ \forall n \geq 2: 16n \log n \leq n^7 \log n$.
For the last term we can use a similar argument to show that $\forall n \geq 2: 12n^{\frac{5}{2}} \leq n^7 \log n$.
At this point we have shown that all terms are smaller than $n^7 \log n$.
What's the conclusion now?
At the beginning, before I verify that $g(n)=\Theta(n^7 \log n)$ can I just say the following?
We see that the dominant term of the function $g(n)$ is $n^7 \log n$, so: $g(n)=\Theta(n^7 \log n)$ ?
Or is there a better way to explain why we suppose that $g(n)=\Theta(n^7 \log n)$? (Thinking)
By definition
$$T(n) = \Theta( G(n) ) \, \implies \,\, \lim \frac{T(n)}{G(n)} \to c \, ; \,\, 0<c<\infty $$
Suppose that $f(n) = a(n) +g(n)$ where $a(n)$ is the dominant term so
$$\lim_{n \to \infty } \frac{a(n)+g(n)}{a(n)} = 1+ 0 = 1 $$
So $T(n) = \Theta (a(n)) \blacksquare $.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
I am trying to run an .ipynb file and have installed Miniconda as well as created an environment as such -conda create -n <env_name> python=3.7 ipykernel jupyter I am assuming this is successful as I can activate this environment via the anaconda prompt and following command -conda activate <env_name> Then I downloaded and installed VS code and I am trying to edit an .ipynb file. I want to select a kernel, via VS Code but when I press the button on the upper right corner I am greeted...
