K Type Thermocouple Probe short Circuited with Metallic Body
  • Thread starter Thread starter arham1026
    Insulation Sensor
The K-type thermocouple probe is experiencing a temperature drop to zero when placed in a metallic box, likely due to short-circuiting with the box. Insulating the probe with a thin epoxy coating can help maintain heat transfer while preventing shorting. Users suggest checking the thermocouple's connections and grounding to diagnose potential issues, as an open circuit may also cause erroneous readings. It is recommended to verify the serial data for any indicators of an open circuit condition. Proper grounding and insulation are crucial for accurate temperature measurements in this setup.
arham1026
TL;DR
I am Measuring the temperature of metallic box with K thermocouple probe. As soon as probe is place in cavity of metallic box, the temperature readings goes to 0C.
I measure the temperature of metallic box using K thermocouple probe along with MAX6675IC to digitize its output. As soon as probe is placed in the cavity, the temperature drops to zero. I suspect that probe is being shorted with metallic box.Suggest some way to insulate the probe or suggest some other new sensor(contact based )
I used to glue small TCs onto electronics (transistor cases and such) with epoxy. A very thin coating was enough insulation, but didn't interfere with heat transfer too much. Not a "probe" just the wires, which is mostly all we ever used. A roll of TC wire is cheap enough that you can just cut the end off and make a new junction or a whole new probe. It wasn't unusual to see a power supply in temperature tests with lots of TC wires attached.
Welcome to PF.
One side of the thermocouple pair is grounded, so you should expect a short to result in an offset or noise, rather than zero. Test that condition by grounding the TC probe to T- and to ground.
I expect it is more likely that the TC pair is open circuit, when stretched. Check bit D2 in the serial data. "D2 is normally low and goes high when the thermocouple input is open". Does an open TC circuit return zero data?
Check that T- has a ground connection.
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 45 ·
12K
