Kinematics and One Dimensional Motion
The discussion centers on whether deceleration can be assumed to be the same in different instances of one-dimensional motion. It explores the idea that the acceleration of a car during braking might be independent of its speed. A participant concludes that they have resolved their query, stating the answer is D/9. The conversation reflects a focus on the principles of kinematics and the implications of speed on deceleration. Overall, the thread emphasizes understanding the relationship between speed and braking in one-dimensional motion scenarios.
ayans2495
A car is travelling at 120 km/h, when the driver sees a herd of cows on the road ahead and slams on the brakes. The performance of the car’s brakes is such that the car comes to a stop in a distance D meters. Assuming that the acceleration of the car under braking is independent of the car’s speed, what distance would the car require to come to a stop if it were travelling at 40 km/h instead?
v=d/t, x=ut+1/2at^2
Would we assume that the deceleration of both instance are the same?
I think that's what the question is trying to say, by
Don't worry, I've figured it out. It's D/9. Thank you though.
Not going to ; cheers.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
