Kinematics: Ball Thrown Upward from Building
  • Thread starter Thread starter dboy83
    Ball Kinematics
A ball thrown upward from a 100m tall building takes 6.5 seconds to hit the ground. The initial speed of the ball is calculated to be approximately 16.5 m/s. The downward acceleration due to gravity is considered negative, affecting the displacement and velocity calculations. The maximum height reached by the ball can be determined using the kinematic equations, confirming that the displacement is negative when the upward direction is positive. Understanding the sign conventions in kinematics is crucial for accurate calculations.
dboy83
kinematics-- ball thrown
A ball is thrown upward from the edge of a building that is 100m tall. On its way back down, the ball just misses the building, falling to the ground below. The elapsed time between the throw and the ball hitting the ground is 6.5 sec.
A) The initial speed of the ball
B) Position and speed of the ball after 1 sec and after 4 secs.
C) The maximum height reached by the ball, measured above the ground.
*Ok, I've worked a few problems where the object is dropped directly from the top of the building but none where the object is actually thrown upward!*
Well u just hav 2 use the same equations of motion
The usual convention for these 1s is up is positive and down is negative so the initial speed u is a positive num since in the up direction. The displacement s will be -100 and g is -9.81. Putting in the numbers:
s = u*t - 0.5*g*t^2
-100 = 6.5*u - 0.5*(9.81)*(6.5)^2
-100 = 6.5*u - 207.236
6.5*u = 107.236
u = 16.498
To get the speeds just use v = u - g*t
positions: s = u*t - 0.5*g*t^2
U can use the fact that v becomes 0 at the max height to find it:
v^2 = u^2 - 2*g*s
u^2 = 2*g*s
s = u^2/(2*g)
why?
s = u*t - 0.5*g*t^2
6.5*u = 107.236
u = 16.498
v^2 = u^2 - 2*g*s
u^2 = 2*g*s
s = u^2/(2*g)
why is s -100? I thought it should be +100 ?
d=v0*t + 0.5at^2 isn't that the correct formula?
Yes. But a = is negative if up is positive. Final d (vertical displacement) has to have the opposite sign of v0 and v0 has to have the opposite sign of a since v and a are in opposite directions.
I would suggest that you plot a graph of velocity vs. time and the up direction positive. The graph is a straight line with slope -9.8 m/sec^2.
[Of course, you could also do it with the down direction being positive and the slope + g but then the initial velocity would be negative.]
AM
PS and do not double post!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
