Kinematics, given only vi vf and d
  • Thread starter Thread starter Omnistegan
    Kinematics
The discussion revolves around a kinematics problem where initial velocity (vi), final velocity (vf), and displacement (d) are provided, but the values lead to confusion. With vi at 7.185 m/s, vf at -7.185 m/s, and d at 0 m, participants argue that the problem cannot be solved for acceleration (a) and time (t) as the equations yield zero. The consensus is that the question may be misinterpreted or incorrectly stated, as the given data does not allow for a meaningful solution. The issue highlights the limitations of kinematic equations when displacement is zero. Overall, the problem remains unresolved due to insufficient information.
Omnistegan
Kinematics, given only "vi" "vf" and "d"
I have a hunch this problem is impossible with the given information.
Using the given information, solve for a and t.
vi = 7.185m/s
vf = -7.185m/s
a = ?
d = 0m
t = ?
Not sure, I think this would be correct.
vf^2 = vi^2 + 2ad (The problem here is obvious when d = 0)
d = 1/2(vi+vf)t (Once again, as far as I can tell, useless when d = 0)
Well I can plug and chug the numbers the same as anyone, the problem is that it will always come out to zero.
Thanks in advance guys.
Are you sure d=0? What is the original problem statement, word for word?
d certainly is 0.
The question is exactly as I have above.
My impression was that this question resembled the vertical component of a projectile motion question. Up and back down, 0 displacement.
My opinion is that it can't be solved with only that information. Perhaps we're thinking too hard though
It would seem to me that the question has been misinterpreted, or miswritten. I certainly don't see a way to solve it with the current data.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
