Kinematics of Rigid Bodies in 3D
The discussion focuses on a kinematics problem involving rigid bodies in 3D, specifically analyzing the motion of a hoop in relation to a pole. The user defines fixed and rotating axes at the contact point and derives equations for angular velocity and acceleration. An initial error in calculating acceleration is identified, where a factor of 2 was mistakenly included in the final expression. The user resolves the issue by recognizing the omission of a crucial term in the acceleration formula, which corrects the calculations. This highlights the importance of careful term inclusion in kinematic equations for accurate results.
yoft
Problem 15.18:
I've defined the positive J (fixed) axis along the pole pointing upwards and the positive X (fixed) axis going to the right, with both centered at the point of contact between the hoop and the pole, which I will refer to as point O. The rotating axes (lower case) are defined along the fixed axes at this particular moment.
ω=Ω(J) + v/R(k) = Ω(j) + v/R(k)
α=(Ωv)/R(i) <-- derived from the first expression of ω
VA = VO + ω x rA/O + VA/O = v(j) - 2ΩR(k)
aA = aO + α x rA/O + ω x (ω x rA/O) + aA/O = (-2Ω2R-2v2/R)(i)
My issue is that my v2/R term in my final acceleration is off by a factor of 2. I get -240 ft/s2(i) when I should be getting -216 ft/s2(i). Can anyone point me towards the step that I multiplied by 2 when I shouldn't have?
Actually I found the problem, I left off the 2ω x VA/O term in the acceleration formula. That adds in another V2/R term that solves my factor of 2.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
