Kinematics/uniform circular motion.
The discussion revolves around calculating the centripetal acceleration of a ball in uniform circular motion before the string breaks. The initial attempt incorrectly used the time of fall to determine the period of rotation. It was clarified that the period (T) should represent the time for one complete revolution, not the fall time. After determining the horizontal velocity of the ball using projectile motion principles, the correct centripetal acceleration was calculated as 86.02 m/s². This highlights the importance of distinguishing between different types of motion in physics problems.
Muneerah
A ball on the end of a string is whirled around
in a horizontal circle of radius 0.28 m. The
plane of the circle is 1.44 m above the ground.
The string breaks and the ball lands 2.66 m
away from the point on the ground directly
beneath the ball’s location when the string
breaks.
The acceleration of gravity is 9.8 m/s2 .
Find the centripetal acceleration of the ball
during its circular motion.
Answer in units of m/s2.
T= \sqrt{}2y/g
ac=4*pi2r/T2
First I found time using this equation T= \sqrt{}2y/g
=T= \sqrt{}2*1.44m/9.8m/s= .5421047s
then I plugged my time into the acceleration equation ac=4*pi2r/T2
= 37.61415924 m. My answer is wrong and I would like to know what is it that I did wrong, I tried many ways to do it, but non of the answers I get are right, if you can please calrify. Thank you.
The symbol T in the expression for the centripetal acceleration is not meant to be the time it takes the ball to hit the ground. It is the time the ball requires to complete one revolution, i.e. the period. T is what it is regardless of whether the string breaks or not. It is related to the speed v at which the ball goes around before the string breaks.
After the string breaks, you have projectile motion. Answer this question first, "How fast must the ball be moving in the horizontal direction so that it hits the ground 2.66 m away in 0.542 s?" This will give you the speed of the ball v. Knowing v, you can then find the centripetal acceleration. There is an expression that relates the centripetal acceleration to the speed. What is it?
Ok so basically to find the Velocity I used X/t = V
V= 4.907749077 m/s
centripetal acceleration = V^2/r
= 86.021432 m/s^2 and that is the right answer, thank you so much for helping me.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
