Kinetic Energy and bowling ball Question
In summary: But since I didn't, I had to solve for it again.Your looking for the KE just before the ball hits the floor. In order to do that, you need to first find it's velocity just before it hits the floor. So you do PEi + KEi = PEf + KEf. KEi goes to 0 since it's starting from rest, and PEf goes to 0 since y=0 just before it hits the floor. So you're left with PEi = KEf, which can also be written as mgy = 1/2mv^2. Plug everything in: (7)(9.8)(2)=1/2(7)v^2you get v
JCB
A 7kg bowling ball falls from a 2m shelf. Just before hitting the floor, what will its kinetic energy be? (air resistance is negligible)
KE = 1/2mv^2
m = 7kg
Δy = 2m
g = 9.8m/s^2
Vi = 0 m/s
I solved for the final velocity, using PEi + KEi = PEf + KEf, and found it to be 39.2 m/s. Then, I plugged that into the equation KE = 1/2mv^2, and got the Kinetic Energy, but my answer was way off. (The correct answer is 137J)
KE = 1/2mv^2
m = 7kg
Δy = 2m
g = 9.8m/s^2
Vi = 0 m/s
You have the correct relevant equations. But you left out the formula for PE. Define what PE is and try again, please.
PE = mgy
but I don't need any help on this. I realized what I did wrong: nothing!
I got v^2 to be 39.2, and forgot to solve for just v.
That would explain a lot.
JCB said:
PE = mgy
BUT why are you solving for V? you're working in reverse. You have to find the KE first, then you solved for V, then you plugged it back and solved for KE again?
you get v^2=39.2
and me being the lazy guy I am forgot to write v^2 and just wrote v, which meant my final velocity was way off. Once I realized I forgot to square root each side, I was able to get the real final velocity (6.26 m/s) and then plug that into KEf = 1/2mv^2, which means KEf = 1/2(7)(39.2), which means that KEf = 137.2 J.
So, in short, I couldn't solve for KEf to begin with because I didn't have the final velocity to begin with. If I already had the final velocity, that would have been a joke question.
FAQ: Kinetic Energy and bowling ball Question
What is kinetic energy?
Kinetic energy is the energy an object possesses due to its motion. It is the energy required to accelerate an object to its current speed.
How is kinetic energy calculated?
Kinetic energy is calculated using the formula KE = 1/2 * m * v^2, where m is the mass of the object and v is its velocity.
Why is kinetic energy important in bowling?
Kinetic energy is important in bowling because it is what gives the bowling ball its momentum and power to knock down the pins. The more kinetic energy the ball has, the more pins it can knock down.
How does the weight of a bowling ball affect its kinetic energy?
The weight of a bowling ball directly affects its kinetic energy. The heavier the ball, the more kinetic energy it will have when it is thrown down the lane.
What factors can affect the kinetic energy of a bowling ball?
The kinetic energy of a bowling ball can be affected by its mass, velocity, and any external forces acting upon it, such as friction from the lane or air resistance.
