Kinetic Energy and friction problem
The discussion centers on a physics problem involving a 70kg base runner sliding into second base at 4.0 m/s, with a coefficient of friction of 0.70. Participants are tasked with calculating the mechanical energy lost due to friction and the distance slid before coming to a stop. The kinetic energy equation, 1/2mv^2, is identified as relevant for determining energy loss. The force of friction, calculated as 0.7 times the runner's weight, is considered significant for solving the problem. Understanding the relationship between friction, kinetic energy, and distance is crucial for finding the answers.
Zerobu
A 70kg base runner begins his slide into second base when he is moving at a speed of 4.0m/s. The co-efficient of friction between his clothes and the Earth is 0.70. He slides so that his speed is zero just before he reaches the base
(a). How much mechanical energy is lost due to friction acting on the runner?
(b) How far does he slide
I think this has something to with the kinetic energy equation which 1/2mv^2
I have no idea how to do this
You don't think that since they tell you that "The co-efficient of friction between his clothes and the Earth is 0.70." and that his mass is "70kg", the fact that there is 0.7(70)= 49 N force acting on his is at all relevant?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
